Old 05-12-2014, 06:11 PM   #1
Ed Wright
Ed Wright's Avatar
Default Re: Lokar Trans Dipstick...
My pan had to come off.
Ed Wright 4156 SS/JA
Old 05-12-2014, 06:44 PM   #2
brent flynn
brent flynn's Avatar
i think that will be the one that i get... im tired of not being able to get to that bolt, and i need it , anyway... been putting it off for awhile now...
My engine is still out, trans pan is drained( because i have to remove the OEM type dipstick), so now would be a good time to install it...
Cam should be here tomorrow, pick up heads tomorrow eve, then sending cam/lifters out for coating...
Old 05-12-2014, 08:16 PM   #3
R. Thorne
Liked 100 Times in 33 Posts
I drilled a hole in the firewall to access the bellhousing bolt on my car (74 gto), then plug it when not in use. When I put the turbo 200 in the car I had to use the Lokar dipstick for clearance reasons. I also mounted it on the firewall away from that bellhousing bolt. I would much prefer the stock type dipsticks. The problem with cable type dipsticks (Lokar, etc.) is they bend and flex going around tight corners and that can throw off your readings as much as a quart. Ron.
R. Thorne is offline   Reply With Quote
Old 05-13-2014, 07:52 PM   #4
brent flynn
Good info.. Ron... Im up in the air about what to do... im still leaning toward the lokar... good news is, i kept the fluid that i drained out...so it would let me know
where im at, for the most part,,,,
Old 05-13-2014, 08:21 PM   #5
brent flynn
The ATi deal, will fit stock GM dipstick, correct? I could get the ATI deal, for temporary purposes, and then do the Lokar later this year... because, i'm not pulling this engine anymore, this year...hehe
