Old 05-10-2014, 09:26 AM   #1
richie 2
Liked 200 Times in 91 Posts
Default Sbc holley intake
older holley strip dominator ntake #06266....any idea what the power range might be?
Old 05-10-2014, 12:09 PM   #2
MAURICE BLENDHEIM
Liked 278 Times in 86 Posts
Default Re: Sbc holley intake
Richie…The old Holley intakes were either a 300-2 or a 300-25 (look on the bottom for numbers). The early 300-2's were shorter and were described to work better with manual transmissions. The 300-25 offered better design to enhance torque curve and referred for automatics. The 300-2 was advertised for 3500-7500 RPM and the 300-25 was 4500-7600 RPM. Both manifolds hold themselves to 8000 RPM. The 300-25 is the preferred design. Our results have shown a more broad torque over the Victor JR. (3500-8000). Hope this helps…Maurice.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 05-10-2014, 01:06 PM   #3
richie 2
thankyou my fellow canuck Maurice for the info... ill get the part number...go habs go!
Old 05-10-2014, 06:54 PM   #4
Tim H
Tim H's Avatar
Liked 481 Times in 158 Posts
Go Habs Go !!! Only minutes until game time !
Old 05-10-2014, 08:49 PM   #5
richie 2
hey tim...three/zip bruins...I should have gone to brockvegas for there opener tonite! any 350ci 4 blt. block's you know of around there?
Old 05-10-2014, 09:39 PM   #6
Tim H
Tim H's Avatar
I thought Brockville was going to be rained out ... bruins now up 4-1
Old 05-11-2014, 01:55 PM   #7
richie 2
scored ok murice...#300-25 alright. $100.00 purchase for my 350ci/auto bracket combo w/intensions of using an Q-jet & adpter on top. other than a basic port match i'll leave it alone...should work great !!!
Old 05-11-2014, 06:24 PM   #8
MAURICE BLENDHEIM
Richie…There is a few ponies in the top just below carburetor flange a nice gentle radius in the corners and the runner divider edges generally need a little tidy up. But don't get carried away, use low RPM on the grinder. Good Luck…Maurice.
Old 05-11-2014, 06:27 PM   #9
MAURICE BLENDHEIM
Oh and by the way you forgot the "EH" in my name. (Canadian for "A")
