Old 05-01-2014, 11:07 PM   #1
MAURICE BLENDHEIM
Liked 285 Times in 87 Posts
Default Re: Improving 60' times, third gen f-body
Tony...4.10 - 4.56 -4.88's alone should put you into the low 1.40's maybe high 1.30's if your lucky. Faster by adding something like a 4000-5000 convertor, but you may sacrifice the street car thing? Your intake and cam will become a factor the closer you come to 7000 RPM. Hope this helps...MB.
MAURICE BLENDHEIM is offline   Reply With Quote
Old 05-02-2014, 08:32 AM   #2
TonyB83
Thanks again for all the replies.
Consistency is what I'm after here. While I'm not opposed to a gear and converter change, I'm more interested in suspension tuning at the moment. Do you guys think I'd benefit from either coilovers or adjustable shocks? I see a lot of guys on here who are running well with the Lakewood 90/10's and 50/50's but I also see a LOT of you who have gone to coilovers or adjustable shocks. What is the determining factor here? I'll admit, I can't justify the $1500 for the Santhuff stuff but I'm open to recommendations.
As a side note, I measured the angle of my LCA's last night. They are in the bottom hole of the lca bracket ( I know you guys hate them) and are at +5*. Moving them to the next higher hole looks like it would give them a negative angle and put the IC behind the car.
TonyB83 is offline   Reply With Quote
Old 05-02-2014, 09:01 AM   #3
njk53
I think your suspension set up seems to be good and going to high dollar adjustable shocks and coil overs will only get you marginal benefit. As stated by Doug try a 4:56 or similar gear with with a taller tire and see what happens.
Nelson Kowal
Stock 345
