#11 | |
Liked 13 Times in 11 Posts
That and softer rear shock settings maybe? |
#12 |
Liked 4 Times in 3 Posts
Go to a track that has some bite, Silver Dollar on a test & tune or weekly race does not have it. The wind blows a lot of sand on track, on Friday nights we blow the tires off in 4th gear. Commerce is not a lot better on a normal week.
Everett Hill 2134 STK, SS |
#13 | |
![]() I hear what you are saying , but I still have issues.......... |
#14 |
Liked 36 Times in 26 Posts
I leave at 5700 right now, and we will move that around a little to get the 60 FOOT , where they need to be, so that the package will be close to the 9.9. 7000 sounds like you at the top of what you can get. I really don't believe that you will get a whole lot more, by bringing it out at 8. Are you hooking or spinning, are you carrying the front out? I would step back from the car and try to find a little more power. Slipping the clutch is ok, but I feel it is a slippery slope, to get it exactly the way you want. I would not push your package too much, just race it and enjoy it, especially if it will be consistent and RELIABLE. Man, you must be buzzing that thing at the finish line with a 5.86. Are you in high gear at the 330 ft mark? I had 5.43 gear and it ran good, but I am at 4.86 now, and it is almost too much. My cube is 352, 5 speed and I am in high gear before the eight mile, I like to spred the gear changes out as far as I can
#15 | |
I need the 1.29 or better 60 fts and I will work on it til I achieve it ![]() Be it thru shocks , IC , pinion angle , clutch......whatever. |
#16 |
Liked 22 Times in 22 Posts
Joe, your car is fast enough to turn a 1.35 into a 1.26, 1.27 60' easy. We ran high 9.60's, low 9.70's and ran several 1.28, and 1.29 60's We did better with the shocks set stiff in the rear, and front, and the limiters tied down to 1" travel. Same basic tire you're running, but a 6.20 gear, 3.39 low. Also a soft loc clutch. Your ladder bar set up is still very capable of 1.20's. And we are completely lost in the bell housing.
don,t have one |
#17 | |
![]() Anyway , please show me how dumb I am and come fix it..........I'm gettin old and tired , but still willing LOL BTW how much base did you run and are you clutch assisted? |
#18 |
Joe, I'm the wrong guy to ask on clutches, chassis, etc. I'm barely smart on engines, but I will tell you what little I know. Yes, we were truly clutch assisted, clutching every gear. And sir, I made a mistake with the clutch deal. We were running the soft loc in the dart buick, which was 100 HP better then the iron head 291. it went 1.26 in 60. The runs we ran high 9's and 60 footed high 120's we were running a ram street strip rag, 30# steel fly wheel, and 1800# base. On the dart buick we ran sintered iron, aluminum 18# fly wheel, and i think 350 base. We ran better with the heavy pressure plate and fly wheel on the 630 HP motor, and ran better on the 720HP motor with the lite stuff. I know other people all run better with the lite stuff, but we never quite figured it out. And yes we go through the lights at above 10,000 in the 1\4. We also ran better leaving at 8,800 then we did leaving at 9,700. There's way smarter guys on here to help you with your 60 ft. then me.
don,t have one |
#19 |
Liked 2,490 Times in 700 Posts
If it spins it will Pick up 2 or 3 TENTHS faster ET?
#20 |
Yeah GTX John, you heard me right, it will pick up 2 to 3 tenths if it does not dead hook. This is a Super gas car, if I feel it spin the tires, I know I am going to be way fast, and have to pedal it at the big end. I have attempted to run hi 8's with it and it has to spin the tire, to even get close. Do you know any stock stick cars that dead hook and run.fast? I think even pro stock like to spin the tire some. Auto cars to me like to dead hook. Yeah it pulls the motor down on the launch, but it moves.
