Old 04-10-2014, 03:44 PM   #11
Bob Gullett
Bob Gullett's Avatar
Liked 507 Times in 116 Posts
Default Re: Weather station
Originally Posted by Don Higgins View Post
The only reason any weather station will "step over" another is if the transmitter has been modified and now "bleeds over" to other frequencies. They think it helps the range but it really does the opposite.
The only place I see this is in Division 7 where some Top Alcohol team ( yet to be determined ) which causes problems for racers at Vegas and a few other places.
There are a million frequencies and many millions of cap codes for the pagers so there should be zero problems.
One other item is to make sure your paging weather stations do not have the antenna wire coiled up, that causes problems for some.
That explains why at the last 3 Vegas races the pager sometimes would not read correctly once in a while. Interesting!
68 Chevy11 327 F/S
Bob Gullett is offline   Reply With Quote
