Liked 883 Times in 237 Posts
Jeff ,occasionally you will have one station stepping on another, its usually not a problem at Divisional races but with all the radio traffic at National events , I have seen issues with signals reaching the staging lanes. Maple Grove in particular can be difficult because of the pit layout.
The only reason any weather station will "step over" another is if the transmitter has been modified and now "bleeds over" to other frequencies. They think it helps the range but it really does the opposite.
The only place I see this is in Division 7 where some Top Alcohol team ( yet to be determined ) which causes problems for racers at Vegas and a few other places. There are a million frequencies and many millions of cap codes for the pagers so there should be zero problems. One other item is to make sure your paging weather stations do not have the antenna wire coiled up, that causes problems for some.
Don Higgins - Super Comp #360H |
And literally no one in the world other than drag racers using pagers since about the mid-1990s, so...
Chris Williams 6304 SC, TD, ET |
#4 | |
Weird, just this week at the hospital the doctors and nurses all had one, every restaurant I went to they gave us those disks that vibrate ( which are just pagers by the way ), and "Blart" the mall security guard had one. They didn't get the message apparently.... ![]()
#5 | ||
Thank you all for some great information. I will go with the hand held weather Performaire, Eclipse.
#7 | |
Liked 507 Times in 116 Posts
68 Chevy11 327 F/S |
