#1 | |
Chad Rhodes 2113 I/SA |
Liked 189 Times in 48 Posts
Any thoughts about coating on a stainless header?
would there be any advantage there... other than that you would have to worry about the headers rusting from the inside out?
Angelo DiTocco '98 Firebird SS/HA '98 Firebird B/SA |
Liked 805 Times in 245 Posts
I've built lots of both ms & ss headers. In spite of price, ss is definitely the way to go, virtually indestructible. Having run both ss and ms headers on my own car, I can tell you that they hold heat way longer than ms, you can't get anywhere near them even 20 minutes after coming back from a run. Regarding tri Y's, don't consider them unless you are willing to commit the time to tuning things in, they are very unforgiving if you miss on the combination. In an ideal world, I would recommend ss headers and having them coated to at least keep the under hood heat radiation under control. The other negative to ss (besides the cost) is that the tubing tends to be 16 ga and that makes the overall weight higher, I have always prefered to use 18 ga on race headers just to keep the weight down. If money is really not an issue, consider the Nascar tri Y paper thin Inconell version, can't even imagine what those cost.
Jim Caughlin SS 6019 |
Liked 564 Times in 66 Posts
Approx $9000+/-
But they can be very brittle. My Elston Stainless both sides together weighed less than one side of our old Heddman headers. Last edited by Bill Grubbs; 04-07-2014 at 12:06 PM. |
Liked 165 Times in 59 Posts
I have been build headers for several years now ,steel and stainless , I always suggest the stainless ,, you don't have to coat them and no rust issues will offset how often you will have to coat steel and rust will build up in steel no matter the company who does them ,, also if your building new engines and dynoing them with coated ones you will burn the coating off the top bends , but ceramic coated headers do offer the heat being contained in side the tube ,, stainless doesn't offer any heat barrier , if your r&d ing with header sizes a lot then steel is the way to go gmonde
www.gmondeperformance.com |
Liked 316 Times in 67 Posts
I talked with Kromer a few years ago and he needed the car on premises...do others mentioned here (Lelchook, REF, Elston etc) have that same requirement?
Kromer also requested spec sheet on port design, flow, etc.....others? Thanks in advance for any opinions I run my 1995 Jack Davis headers, it sounds like I may be giving something up, they are looking kind of rough |
Liked 6 Times in 4 Posts
gmonde... Your site link shows a virus. My AVG caught it...
#8 | |
Liked 805 Times in 341 Posts
Bill |
