Old 04-01-2014, 12:04 AM   #1
Aubrey N Bruneau
Aubrey N Bruneau's Avatar
Liked 7 Times in 3 Posts
Send a message via Yahoo to Aubrey N Bruneau
Default Re: Ordering New Transmission, but What Gears ?
I did in Medicine Hat... but traction wasn't dependable. When it did hook, it bogged.
I don't go there any more.
Hoping for Mission in early June, but we're going on a big trip in May, for our daughter's wedding. That may stifle that particular race.
Aubrey N Bruneau 6409 C/S
62 BelAir sport coupe, 409 HP 409
Aubrey N Bruneau is offline   Reply With Quote
Old 04-01-2014, 01:18 AM   #2
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: Ordering New Transmission, but What Gears ?
I hope you can pull it off, Aubrey. It would be great to see you and the car again at Mission. Its one of my "must do" trips every year at one of my favorite tracks. Take care.
Danny Durham
Old 04-01-2014, 11:00 AM   #3
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Aubrey, I would not be afraid of the 3.19 first gear. The super light clutch-flywheel assembly will allow you to accelerate the car without wheelspin. I would go with a 2.00 second and 1.40 third with the 3.19. The faster you can accelerate the car in the first half of the track, the lower the ET. Race setups have you in high gear at the eighth mark and it's just the ride from that point on regardless.
Old 04-01-2014, 08:32 PM   #4
Pvt Parts
Pvt Parts's Avatar
Yep...
Old 04-01-2014, 08:57 PM   #5
Todd Hoven
Guest
Posts: n/a
Yep...
X2.
Old 04-01-2014, 09:34 PM   #6
Dave Casey
Liked 804 Times in 168 Posts
I like the 319,200,140 idea, but you and I have tractor motors that few stick guys have. I like the 308 in my 400/427 stocker. Your car is 400 lbs heavier, but you have the rear gear to offset that. Todd,s thought on leaving lower with more 1st gear is certainly a good one, and his combo is closer to what you have, worth trying, and easy to switch 308 to a 319
Dave Casey 1330 STK
Old 04-01-2014, 11:28 PM   #7
Run to Rund
Liked 54 Times in 27 Posts
I like the ratios that I got with the 3.08 first, and if I went to 3.19 first, I would still want about the same for second and third as I have now (1.93, 1.34). The engine seems to recover a lot easier in the lower gears, and a wide 3-4 seems to slow down the engine's building rpm. About the worst was the old M20 with its 1.48 or 1.46 third ratio.
Old 04-02-2014, 12:02 AM   #8
Liked 1,912 Times in 429 Posts
Yeah, that also fits in with the fact that he has changed to the correct theory on camshafts now, I'm betting he'll find more power and more RPM working with the correct lobe designs. That gearing combination will allow him to put the gains he'll make in the future to good use. Not breaking valvetrain components will allow him to race the car and learn, instead of trying to keep it in one piece and running. Racing is about to get much more fun!
Old 04-02-2014, 12:56 AM   #9
Aubrey N Bruneau
I like your optimism, Alan !
Thanks again, everybody.
I'm going to get back on the phone with Jerico, and come up with a combination based on what I'm hearing here. I DO want to stop breaking the engine because of the valve train... while not choosing a gear combination that will break the transmission !
My daughter is getting married on a cruise ship, touring between Italy and Spain.
HHHMMM....
May have to settle for on a row boat in our local pond.
Old 04-02-2014, 01:27 AM   #10
Adger Smith
Liked 880 Times in 311 Posts
If I were you....
Take a wide path around those rocky shores(no short cuts) and find out the captians name. You might also ask him if he is kin to another well know boat captian that runs over rocks.
If you get the wrong answer I would settle for the row boat!!
Adger Smith (Former SS)
