#5 | |
Liked 237 Times in 126 Posts
One door has been removed but the other is still on and moves freely. The fuel tank and complete rear end is out of the car as is the engine and trans, so the weight is about as far down as I can get it. The Detroit Speed mini tub kit is similar to the one offered by ChassisWorks/Total Control for the pre 1970 Mustang. It replaces a section of the frame rail with a piece that is the same height as stock but jogs in to make the frame parallel behind the rear tires, so the floor remains unchanged. Currently, I have no rear end or axle. Just a budget. A shipment from MoneyMaker should come Tuesday with Cal traks, Calvert's split mono springs and a hanger kit from Alex D. at MMR. Thanks for the help and input. Dale
