Old 03-12-2014, 09:34 PM   #11
Pedigo Perf
Pedigo Perf's Avatar
Liked 30 Times in 17 Posts
Default Re: big base circle cam in stock elem.
Originally Posted by Jim Hanig View Post
How can they change their mind now I thought this was a done deal a year ago.. Not that they will ck for it any way.
Trust me, they definately do check for it. And pulling the cam out is apparently necessary to measure it. Not much fun, and hard on the tennis elbow when your balancer is as tight as mine is. Fortunately I had a stock size cam bore but I had intended to go with a 55mm but just didn't get it done in time.
I have an email indicating the large core cam is ok as long as you aren't using roller cam bearings. I will try to find it and post it if I can.
Tracy
Pedigo Perf is offline   Reply With Quote
Old 03-12-2014, 11:17 PM   #12
Todd Hoven
Guest
Posts: n/a
I've never done it, but pontiac has problems with cam bearings. If you spin one and do excessive damage to the journal how would you repair it? They don't make an oversize cam bearing for my deal. I think the 50mm would be logical for a repair.
Now that is funny! There is a difference between repairing a block and machining the camshaft tunnel to use a bigger diameter cam.
Old 03-12-2014, 11:33 PM   #13
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
A decent machinist could make a sleeve and the machining process would be similar to sleeving a cylinder.
Old 03-12-2014, 11:37 PM   #14
SHANE R
NEXT THING YOU KNOW, FUEL INJECTION WILL BE ILLEGAL ON 69 CAMARO'S ?????????
SHANE R is offline   Reply With Quote
Old 03-13-2014, 12:05 AM   #15
SStockDart
SStockDart's Avatar
Liked 574 Times in 212 Posts
Paul, you are assuming that you use a standard cam bearing and not a roller bearing, right? I believe that is the issue.
Old 03-13-2014, 12:06 AM   #16
TILBURG
Liked 79 Times in 7 Posts
The first post was about "BIG BASE CIRCLE" cams. When someone has a minute could you please forward me a spread sheet w/ what the stock base circles are for everything amc,ford,chry.chevy,hudson (you never know) What if you have big power adder like a 4/7 swap cam? And it ends up being the same as a ford would something like that be considered as crossbreeding?How do you tell the car (driver) in say B stock auto that just got his 440,396,427 etc A#S drug down the track by a 2014 302 you have to go home because your base circle is to big.
TILBURG is offline   Reply With Quote
Old 03-13-2014, 12:37 AM   #17
Paul Precht
Just talkin about a repair for a stock Pontiac block with standard cam bearings, that's what I thought Todd was referring to.
Old 03-13-2014, 01:50 AM   #18
SStockDart
SStockDart's Avatar
I guess I don't really understand the issue here....What is the advantage to a large bearing cam shaft, as opposed to a standard bearing...????? I understand how a roller bearing camshaft bearing might make a half a horsepower.....plus add to the longevity of the engine. but a standard cam bearing versus a larger one??????? then why do Mopar guys use smaller rod bearings (chevy)...??? I'm just saying
Old 03-13-2014, 05:28 AM   #19
Billy Nees
Liked 7,789 Times in 1,744 Posts
The issue here isn't the larger cam bearing, it's the larger base circle LOBE that the larger bearing register allows you to fit in.
Billy Nees 1188 STK, SS
Old 03-13-2014, 06:36 AM   #20
Todd Hoven
Guest
Posts: n/a
Exactly!! Great post.
