Liked 53 Times in 16 Posts
Hello, going through my rear for the Impala, 12 Bolt w/ spool and 4:88 Pro Gears- what amount of backlash should I be looking for?
Thanks! Will Lamprecht 65 Impala 396-325 I/SA in progress |
Liked 33 Times in 16 Posts
I look for .006 - .008 in our car.
Rich Taylor I/SA - 321 |
.005-.009 with automatic...tighter with stick
Liked 719 Times in 220 Posts
In all the 12 bolts I did, I tried to get .008" back lash,on a street application, as much as .010' is OK due to the fact that any heat soak can cause this spec to tighten up. I'm also assuming room temperature gears at the time of set up. Sometimes, the pro gears take different shims to arrive at the same spec as the street gears.
