Old 01-19-2014, 12:02 PM   #1
1320racer
1320racer's Avatar
Liked 759 Times in 379 Posts
Default Re: Help car drops 700 rpm when going from neutral to first
either lock out the distributor or recurve it so it has ~ 20 degrees initial and 16-18 degrees mechanical advance. Easy to do with an MSD distributor.
Old 01-19-2014, 12:07 PM   #2
ollucky
Distributor locked.
ollucky is offline   Reply With Quote
Old 01-19-2014, 12:10 PM   #3
1320racer
1320racer's Avatar
how's the carb setup/baselined...how/where are the floats set, same question for transfer slots? What is the idle set at? Also how much fuel pressure?
Old 01-19-2014, 12:14 PM   #4
ollucky
how's the carb setup/baselined...how/where are the floats set, same question for transfer slots? Also how much fuel pressure?
Jet size 82 all the way around float level fine. transfer slot I don't know. how do I check?
Old 01-19-2014, 12:20 PM   #5
1320racer
1320racer's Avatar
before you say the floats are fine do this...remove the bowls, invert them and slide a 3/8" or 7/16" drill bit along the roof of the bowl and the top of the float, adjust as necessary.
As to the transfer slots...take the carb off, turn it upside down and look at the slots that are in the wall of each bore. The baseline setting should be about .020 measured with a feller gauge and they should look like this [ ], partially covered by the throttle bore blade(s).
After checking/setting the floats and transfer slots, reinstall, set idle mixture screws, then set idle screw.
7 1/2 is to much, lower it to 6 1/2 for a baseline. If your fuel gauge is liquid filled, get rid of it.
Just confirming, you have no mechanical advance in your distributor?
Old 01-19-2014, 12:33 PM   #6
ollucky
Distributor is locked.
Old 01-19-2014, 12:34 PM   #7
1320racer
1320racer's Avatar
transfer slot(s)
Old 01-19-2014, 12:17 PM   #8
ollucky
7 1/2 psi
