#11 |
Liked 33 Times in 16 Posts
Good deal! I'm going to show this to my partner...he's a big Pontiac fan from way back.
Rich Taylor I/SA - 321 |
#12 |
Awesome! I dig your Camaro...hoping to run into you, not it(hehe) at a divisional this year...Maybe Bowling Green or Indy...
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
#13 |
Update... Pan and front cover on...cam in @ 104.5... Heads are done, staying in the house until i put them on... it was -16* today... I have junk heads on it, to keep cylinders clean and rust free... Next is rockers and pushrods...and then we can prime it! Dont know if INdy in April is a possibility... Too much $ and not enough time... Im thinkin that Joliet in June is a better , more attainable goal... unless i fall into a boat load of $...
#14 |
Liked 333 Times in 180 Posts
what r u using the silver block drivers side lower just above the pan for???
#15 |
The alternator bracket attaches to it... I turn the alt upside down...Smog belt for '85 olds v6..
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() Last edited by brent flynn; 02-12-2014 at 07:18 AM. |
#16 |
Nice! I see a niche market here..
#17 |
Liked 84 Times in 21 Posts
#18 |
Thanks! It works well...doesnt give alot of room behind the Alt, but ive never had a problem... My '62 has same setup on it... and i have a few running around out there, as well... I have a few alum blocks in the cabinet...
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() Last edited by brent flynn; 02-12-2014 at 09:47 PM. |
#19 |
Got the new heads on it, last weekend... I figured out what pushrods i needed, and should have them tomorrow... Once valvetrain is set, i can prime it, and its ready to install... Intake is not bolted on yet, as valley pan isnt either. Gettin closer! Converter is at ATi... should get it back anytime
#20 |
Sneaking up on it Brent. I need to post you up a pic of my partner's '64 tri-power GTO if we ever roll it out of the back shop sometime.
