#24 | |
Richmond synthetic gear oil is API GL-6. I suspect that Royal Purple synthetic is also API GL-6, although they say to use it where GL-4 or GL-5 is required, it is not actually API rated. Torco and Redline both state their gear oil is GL-6. The GL-6 designation is no longer required by any major OE, and as such is considered "obsolete". However, GL-6 is precisely what is required for drag racing, as it is the oil required for high hypoid, high pinion offset, extreme impact, extreme load applications. You probably will not find a GL-6 lube on the shelf at a typical parts house. Note that the looser you run your gears, the higher viscosity you need for severe impact protection.
Alan Roehrich 212A G/S Last edited by Alan Roehrich; 01-14-2014 at 08:11 AM. |
