#161 | |
Its like the NASCAR Late Model Stock round track cars. ( primary market for the W2 and 351N.). They have little 2-bbls. specific intake, and head part numbers. No porting allowed on either. Many strict rules all the way to, and including the primary tube size and collector type and size. The result has been a high "dollar-per-HP" ratio. A "will pass tech" 2-bbl that dynos any amount measurable better is suddenly worth a bunch. Same with every other spec'ed part. Add in the regular trips to the barn if you run good, all these rules made the class more expensive. There is nothing I'd love more than an affordable heads up class. I hope it can be worked out so big spenders advantage can be minimized. It would be a hit with spectators and racers. On the SS/CS thing. Who is/was pushing for the new head rules? As they stand now, Chevy, Ford, and Dodge guys have zero to bitch about. The potential is as evenly matched as you'll find anywhere. Just who had to go and cry for a new head? If it was a well connected racer, you'll still suck because the right people can set records with any of the current brands. If it was corporate, remember Top Stock. |
#162 | |
Liked 1,604 Times in 583 Posts
If you consider the indexes and records in SS/Modified and Comp classes, the automatic transmission cars are faster than the clutchless stick cars. Considering this assumption, the automatic transmission cars should be even faster than the clutch stick cars. There are many clutch cars that can be shifted without clutch. |
#163 | |
Liked 13 Times in 11 Posts
I use the clutch at every gear change..I have to , its an old Nash , so I have to be gentle LOL At this event I wasn't allowed to use the 2 step so I was just playing around with launch RPM ( this wasnt a typical launch RPM ) [ame="http://www.youtube.com/watch?v=3l3WxrHNIHA"]Stick Shift Drag Racing - YouTube[/ame] Last edited by joespanova; 01-05-2014 at 07:29 PM. |
#164 | |
#165 |
Liked 1,875 Times in 422 Posts
The world is full of people who will spend $250K to win a $50 trophy.
You cannot outlaw money in racing. Too many rules stifles innovation, which takes the reward for work out of the class and brings money in. More rules = more money. Rules written to save racers money often, maybe even usually, do not. Racers are not always the best people to make rules. Usually, track owners and promoters do as bad as racers. All three mentioned above have a personal agenda, and even the best of them are biased toward that agenda. What is needed as much as anything is good promotion by good honest promoters. The truth is, if you really want good rules, pay Wesley Roberson, Dave Ley, Travis Miller, and a couple of good engine builders to work on the rules for you. The resulting rules should end up cost effective and enforceable. If you want to try to start the class, start as a part of other non NHRA controlled events, or better yet, series. Good luck to anyone trying to make a class like "econo" modified happen. It would be fun, and interesting.
Alan Roehrich 212A G/S |
#166 | |
#167 |
Liked 22 Times in 22 Posts
OK. One at a time. I've talked to a rep at brodix, and if my memory serves me right, this was 6 years ago, THERE IS NO WAY TO CHANGE THE HEAD, AND INSTALL A NEW SPEC LOGO, OR PART NUMBER WITHOUT BEING CAUGHT. HAVE AN ORIGINAL HEAD THERE TO MEASURE, AND COMPARE!!! Damn guys, I think I could catch that. The problem is, you'd have to have some guts, and kick them out, and fine them BIG TIME! I know Al Parker said if they ever do anything like run this class, let him know the rules, and he could fine print it to be so defined, anything touched, not allowed, would be self evident. I don't know if any of you guys know him, but he is a genius. This is 2014. The tech. to catch these guys, is simple, and unbelievable. I've seen a set of "Under cover" ported heads, and as dumb as I am, I can tell they've been altered. And Joe, getting ready to watch your video. Now, for comp autos. THEY ARE 250 lbs, lighter then the clutch guys. Take that into consideration. I've already explained how to mount a camera on the cage like we did, if anyone is suspected of not clutching. That will cure that little problem. Worked for us.
don,t have one |
#168 |
Joe, sweet video. You'd fit right in. And, you were clutching for sure, but very good at it by the way.
don,t have one |
#169 |
Now, back to SS\CS. I think the heads are close right now. Look what Manns, Bogner, and Venice Perno have done. Leave it alone, but they won't.
don,t have one |
#170 | |
He has his SS/CS engine for sale on this site. I presume other GM racers are the ones that made the request. |
