Old 01-02-2014, 04:39 PM   #1
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
Default Re: Dry Ice in your fuel cell?
Worth the effort in a heads-up...I would'nt want to deal with it otherwise.
Rich Taylor
I/SA - 321
Old 01-02-2014, 08:00 PM   #2
art leong
I did this at Atlanta one year. It was 92 degrees out and my fuel checked at 45 degrees. Got some weird looks, but explained what I did and it checked fine.
I chopped the dry ice up and put directly into the fuel jugs (half full). I laughed at all the looks I got LOL.
It really didn't seem to make a difference. But at the time I was running quite a bit rich.
I think it would have been worth something if I could retune for the cold fuel (at the time I didn't have the knowlege to retune the ecu).
I think I picked up some (.50) mph. In my case the fuel would probably have cooled the intake air (EFI)
Don't have the time or wallet to test things properly. I tried C25 and picked up between .6 and 1.2 mph. But lost 2 tenths in the short time .050 total. So some tuning would probably have been a net gain. This was tested with 3 runs on C12, then 3 runs on C25, then 2 runs on C12. With no tuning changes and not much DA change.
Some day I'll get around to actually making some tuning changes. With cold fuel or C25 (I was told it needs more timing) Don't really need it right now. Can get into instant trouble in good air.
Art Leong 2095 SS
Old 01-02-2014, 08:19 PM   #3
Tom Meyer
Liked 354 Times in 120 Posts
Ever put it your fuel jug yes bubbled like a sob make sure the jug is less than half full ,had frost on the out side of my gas tank. Don't remember what the fuel temp was at fuel check but did go 1.36 under. You do need to jet them to be worth anything. The TAFC and TAD were doing this and now is not legal. Tom
Tom Meyer 5240 SS Stock ???
Old 01-02-2014, 08:59 PM   #4
vic guilmino
Liked 56 Times in 21 Posts
what is ln2
Vic Guilmino 1129 STK
Old 01-02-2014, 09:08 PM   #5
randy wilson
Liked 22 Times in 22 Posts
I think you need to back the timing up a couple of degrees with C-25, and jet up a size or two. Someone may correct me. I purchased two cool cans from a custom builder that you freeze a 16, or 24 oz. beer can filled with water, then slide it down between coils, and fill with water. Don't know if it works, but it looks cool.
don,t have one
Old 01-02-2014, 09:15 PM   #6
Ed Wright
Ed Wright's Avatar
Someone mentioned cool cans. We used to use them, back when my hair was still brown. I used dry ice and rubbing alky in mine when I had my Jr Stocker. If you have any water in your fuel, you will find it. Freezing it in the fuel line up once. LOL
We can't use cool cans like we used to. I was told there can not be anything in it to cool the fuel while going down the track. Only before the run. Makes that pretty useless. I guess an EFI car could run the fuel pump to circulate fuel through it and back to the fuel cell because of the return line they all use. Then dump it. Dry ice is "before the run", but I don't know that the oficials approve. As mentioned, guys I have seen doing it don't put the cap back on too quick. A fuel cel is vented, not a fuel jug.
Ed Wright 4156 SS/JA
Old 01-02-2014, 09:22 PM   #7
randy wilson
You know something Ed, I may have been illegal using a cool can then, but no one ever said a word. But, in back to back test runs, we never really seen anything. What I did see at Bethany was if you laid bags of ice on the intake between runs, there was a much as .03 in it.
don,t have one
Old 01-02-2014, 09:51 PM   #8
art leong
At Indy a few years ago. I saw some superstockers during class carrying fuel jugs with blankets on them. Went over and saw the moisture on the outside of the jugs.
It seemed hush/hush but I Added 2+2. Seemed like a great idea. Especially with fuel injection (injector about 3 inches from intake valve). It has to cool the incoming air. My air temp sensor is way ahead of the injector (so ambient air), so I don't know how much.
Art Leong 2095 SS
Old 01-02-2014, 11:42 PM   #9
Ed Wright
Ed Wright's Avatar
Was worth a couple hundredths on my old '56 Chevy, and the next car, 250 hp 327" '65 Chevelle. My C/SM Camaro didn't seem to care.
Old 01-02-2014, 10:45 PM   #10
Kevin Panzino
Kevin Panzino's Avatar
Liked 776 Times in 142 Posts
Originally Posted by vic guilmino View Post
what is ln2
Liquid Nitrogen, Vic.
Kevin Panzino is online now   Reply With Quote
