Old 12-23-2013, 11:42 AM   #1
cutta
cutta's Avatar
Liked 5 Times in 2 Posts
Default Early Carter AFB replacement
Was looking at the guide the other day and couldn't find a replacement carb for some of the early Carter AFB carbs. I believe the number was 3105s and 3106s ( 1437x1437/1186x1186 ). Just curious of what the suitable replacement carb would be for a SS engine or would one need to locate an original? Also, what is the cfm rating as well? Any info is very much appreciated!
Adriel Paradise, Paradise Racing Team
Driver/Crew Chief(at least my dad claims me to be)
B.S. Mechanical Engineering, University of Arkansas
cutta is offline   Reply With Quote
Old 12-23-2013, 04:01 PM   #2
Dwight Southerland
Dwight Southerland's Avatar
Liked 780 Times in 194 Posts
Default Re: Early Carter AFB replacement
The only aftermarket AFB that was made with the small throttle bores (1 7/16") was the model 9400 or 9410 (400 cfm) and they had wrong size venturi (1.125" pri 1.250" sec.). That size carb you listed was used on a gazillion early MoPars. I would think that other than having to pay for one in good condition, they should be available. You do realize that the exact number does not have to match?
Tell your Dad & Mom I said hello!
Dwight Southerland is online now   Reply With Quote
Old 12-23-2013, 04:34 PM   #3
HandOverFist
HandOverFist's Avatar
Liked 33 Times in 16 Posts
I would think there would be an applicable Edelbrock.
Rich Taylor
I/SA - 321
Old 12-23-2013, 05:24 PM   #4
cutta
cutta's Avatar
Will do, they need all the bright spots in the world right now. I know it doesn't need to be matching but was unsure of the replacement carb to use in its place. I will have to pull out rule book to review rules. Am I right in assuming that the carb only has to match the given dimensions in the guide as long as its an AFB style carb?
Old 12-23-2013, 06:38 PM   #5
Greenlight
Liked 79 Times in 22 Posts
Are you sure you are looking for a 3105 replacement carb? I think that part number was only on a '60-'61 engine.
1960 - 61
361" ENG
2969S, 2970S, 3105S, 3106S, 3140S
CARTER AFB
Edelbrock makes a legal replacement AFB for 1962 thru 1972 Carter AFBs.
The Edelbrock Part Numbers are 1405 and 1406.
Greenlight is offline   Reply With Quote
Old 12-23-2013, 09:37 PM   #6
Paul Precht
Paul Precht's Avatar
Liked 327 Times in 121 Posts
The 361/305 carb has a slightly smaller secondary than the more common 383, 413 or street wedge AFB. A 63 383 AFB I tested on my bench flowed 566 CFM, I think it was rated at 575. The 361/305 is the same size as the 318/260 AFB and is probably in the 500 to 525 range. These AFBs have no weights in the back but work quite well for their size. The way I read it, the 383 to 426/365 can run the replacement carb but not the 361, maybe nobody asked for it, cant hurt to try. If I wasn't neck deep in my 2 projects cars now I would be very interested in the 361/305 as this is the motor that started it all for me back in 71.
Old 12-23-2013, 10:02 PM   #7
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Looks like there is a nice 3105s on eBay right now for $150 !
Old 12-23-2013, 11:14 PM   #8
cutta
cutta's Avatar
Paul, I wish I was at that point. That 61 361/305 looks like fun with the big valves(2.08/1.74).
