#11 |
Long uppers would raise the front end height on a 1st gen. Chevy II, ...which you don't want.
#12 |
Liked 881 Times in 452 Posts
Alan you are spot on when you say the early Nova front ends are different. The 68 and beyond are the same as a Camaro and that may give more options.
#13 |
It seems to me that GM just copied Ford's better idea 60 Falcon
#14 |
Liked 72 Times in 36 Posts
Thanks to everyone who took time to answer my questions . I didn't mean to take over the thread.
Thank You Kenney Kelley |
#15 |
Liked 63 Times in 7 Posts
If you have an early Chevy II, my kit will keep the toe exactly as you set it, all through its travel. Call me at, 402 443 8424 If I happen to not answer, please leave a message.
Eddie Rezac |
#16 |
Liked 7 Times in 6 Posts
Thanks for the replies. This still shot does show camber woes.
[IMG] ![]() Here's a short video that only shows the right side of the car. At about 25 seconds it goes slo mo and shows what's happening to the right side. I can't feel it when driving. I appreciate your thoughts. [ame="http://www.youtube.com/watch?v=I3GIj3xdbnk"]Nova burnout and wheel stand at 75 and 80 dragway - YouTube[/ame] Last edited by Ron Gusack; 12-22-2013 at 12:44 PM. Reason: added |
#17 |
Liked 279 Times in 68 Posts
We tried everything on my son Andrew's car and ended up having to put a steering damper on it. My car is just like his except he has wheelie bars and I don't. My car doesn't shimmy like his did. Both are 70-71 Camaros. The steering damper cured his car.
Greg Hill 4171 STK |
#18 | |
A Chevy II of the 1968 and later can benefit from longer upper ball joints. The kit that I build is for the 1967, and older Chevy II. It is a completely bolt on kit, no bending, or modifying anything else, just follow my instruction sheet, and go racing. Eddie Rezac 402 443 8424 |
#19 |
The Global West control arms have standard BJ's. Is that because they're built in such a way that long ones aren't needed?
#20 | |
Liked 1,925 Times in 432 Posts
I don't think so. All you need are the Glodal West bushings and the 1-1/2" longer upper ball joints in stock A arms.
Alan Roehrich 212A G/S |
