Old 12-21-2013, 06:48 PM   #1
glen myers
glen myers's Avatar
Liked 2 Times in 2 Posts
Default fuel cell alum or poly?
Looking for the pro's and cons of whether to use a poly fuel cell or aluminum.Any thoughts? (drag race application)
glen myers is offline   Reply With Quote
Old 12-21-2013, 09:53 PM   #2
Dyno
Dyno's Avatar
Liked 691 Times in 205 Posts
Default Re: fuel cell alum or poly?
I have seen racers have problems with the aluminum tanks cracking.
Dyno is online now   Reply With Quote
Old 12-22-2013, 01:02 PM   #3
gbur
Aluminum tanks require care in mounting so as they do not crack
gbur is offline   Reply With Quote
Old 12-22-2013, 01:35 PM   #4
Myron Piatek
Liked 138 Times in 51 Posts
Post Re: fuel cell alum or poly?
Cracks may result from being mounted by the 4 tabs onto an uneven or flexing surface. I believe it's suppose to be secured with straps. I think there was a discussion somewhere about that. I must admit that I use the tabs and haven't gotten around to adding straps. But my aluminum cell is mounted on boxed-in rails spanning the spare tire well. That creates a flat, stiffer foundation and helps isolate the cell.
LOCOMOTION Racing
Old 12-24-2013, 10:35 AM   #5
Floyd Staggs
Floyd Staggs's Avatar
Liked 229 Times in 99 Posts
I've got a custom made one that fits under the bed of my pickup. It's mounted with tabs and straps with rubber insulators. Every seam on it has been rewelded over a few years.
Floyd Staggs 787 SST
Old 12-24-2013, 10:45 AM   #6
rallye bob
rallye bob's Avatar
Liked 6 Times in 4 Posts
I have had an aluminum cell (16 gal) mounted in my trunk the same as Myron's for probably 10 years.... Never a leak... I hope I didn't just jinx myself ;-)
Old 12-25-2013, 01:27 PM   #7
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
I mounted mine with firm rubber strips under the tabs. Hasn't leaked in 6 years, but I never knew of this problem. Now I'm worried. I just went through the stock Nova trunk floor with 3/8's bolts.
Ron Gusack is offline   Reply With Quote
Old 12-25-2013, 03:12 PM   #8
Greg Hill
Liked 279 Times in 68 Posts
5gal. Aluminum since the first year they were legal in stock with no problems.
Greg Hill 4171 STK
Old 12-25-2013, 04:18 PM   #9
GUMP
Liked 2,354 Times in 554 Posts
The first one I did was poly. It always seaped around the fittings. I switched to using aluminum on all my cars and have never had an issue since.
Old 12-27-2013, 06:29 PM   #10
G Anderson
Liked 4 Times in 3 Posts
Stainless !
G Anderson is offline   Reply With Quote
