Old 12-16-2013, 08:15 PM   #14
Painter
Liked 162 Times in 45 Posts
Default Re: Check Out The New Rules 12/11/13 NHRA
Jok you what have done is wrong in two areas. That relay is not intended to function as you have installed it. I don't care what you are reading in the specs. This will bite you right square in your *** at the worst possible moment. Also NHRA does not allow this as the disconnect. 500 people are going to post how they have been thru tech 20,000 times but it won't pass a tech person versed in this subject. Sounds good but won't work-trust me on this.
Painter is offline   Reply With Quote
