Old 12-13-2013, 03:27 PM   #1
Todd Bailey
Liked 33 Times in 17 Posts
Default Re: OLD Modified Corvettes
Ed,
Do you remember what the minimum weight was for the class when you ran?
Todd Bailey is offline   Reply With Quote
Old 12-13-2013, 09:13 PM   #2
Ed Wright
Ed Wright's Avatar
Originally Posted by Todd Bailey View Post
Ed,
Don't remember if there was one or not.
Ed Wright 4156 SS/JA
Old 12-13-2013, 11:56 PM   #3
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
The first SM class was 9.5 lbs/ci including driver and 3000 lbs for small blocks, 3250 for big blocks. The next year, when they expanded to A, B & C/SM, the weight breaks were 8.5, 9.5 and 10.5. A was for big blocks with a 3250 lb minimum (or was it 3300?), B was for small blocks with a 3000 lb minimum and any OEM cylinder head, C was for small blocks, true wedge head (valves in a straight line) production only. A allowed an 850 cfm carb, B & C used a 750 carb.
Old 12-14-2013, 08:40 AM   #4
Ed Wright
Ed Wright's Avatar
^^^^^ There ya go!
Old 12-14-2013, 09:52 AM   #5
Dwight Southerland
Correction to my earlier post - minimum weight for A was 3350, according to 1981 rulebook.
Originally, the head limitation was the big deal. You could do anything to the combustion chamber except weld. Limited to 1" porting below the valve seat and 1/4" at the intake port opening. SM racers "found" the 461X heads for C/SM with bigger ports. B class Chevies ran the 292 "Turbo" head with angle plugs. Short stroke big block Chevies were common in A. The Cleveland Mavericks were the scourge in B: Garley Daniels and the Chevy IIs were the ones to beat in C.
Some of my observations for the new class discussions:
1) The spec head idea is good. Something to eliminate limitless spending on heads.
2) Consider limiting to steel valves.
3) Single 750 carb.
4) How about a 10 1/2" tire limit?
5) Hood scoop maximum of 7" above the hood surface at any point. Cut out the goofiness and that gives a little advantage to older bodies.
Old 12-14-2013, 10:46 AM   #6
randy wilson
Liked 22 Times in 22 Posts
Some very good ideas Dwight. The only one I have a real issue with, is the 10.5 tire. And that reason being, mine, and other SS type cars will look awfully goofy with those on because of the current width of rearends. Most, if not all, would have to change rearend housings. I was looking at a more realistic 12.5. And, maybe I misunderstood your post, but I think the older cars are at a disadvantage because of the new cars with the laid back wind shields, and less frontal area. I don't think it matters much in the 1\8th mile, but in the quarter it does matter.
don,t have one
Old 12-14-2013, 11:27 AM   #7
Ed Wright
Ed Wright's Avatar
The correct back spacing wheels will put the 10.5" tires back out where they look fine. Guys were doing that "back in the day" to save weight & unsprung weight.
Sounds like fun, but I don't know how many guys like me with later cars would build another car to run it. Don't know about requiring a stick car, either. Lingenfelter ran an automatic back then. Sticks sure as heck won't do bigger wheel stands for the crowds. LOL
