Liked 19 Times in 8 Posts
Hey guys this is my first time running a stocker and a car with a racepak and i need to know if on a racepak graph after a run if the driveshaft graph shows a spike during/after the shift if that indicates tire spin and if you see spikes down track on the RPM graph after the 2,3 shift if that indicates a high speed miss.Thanks just doing a little after the race troubleshooting.
7015 E/SA Sooner Storm |
#2 | |
Chad Rhodes 2113 I/SA |
Liked 461 Times in 61 Posts
More than likely what you are seeing is the tire unwrapping/ wrapping up around the wheel (drive shaft).
Liked 92 Times in 49 Posts
Which Racepak system are you using? If it has the accelerometer, you can use it to look at spin/hook issues also.
