Old 11-16-2013, 02:13 PM   #1
blueboatcar
Liked 11 Times in 1 Post
Default no change
I've got an M/SA Malibu that runs 12.0's no matter what you do to it. We've changed all kinds of parts tested different tune ups and runs the same every time. The car doesn't even respond to weather runs the same in 4200ft down to 400ft. Has anybody else ran into this issue if so any help would be appreciated.
blueboatcar is offline   Reply With Quote
Old 11-16-2013, 03:35 PM   #2
MEXJOE
MEXJOE's Avatar
Liked 165 Times in 51 Posts
Default Re: no change
12.0's is a strong pass in M/SA, If you are trying to go faster,
look under the carburetor, you will most likely find the trouble there.
I.O.W./ Go to a dyno.
Glen DeMenge
1969 Camaro Stock Eliminator
MEXJOE is offline   Reply With Quote
Old 11-16-2013, 04:08 PM   #3
7423
Wow!!!
Wish I had that problem.............go bracket racing.
Sounds like money in the bank to me.
7423 is offline   Reply With Quote
Old 11-16-2013, 04:14 PM   #4
Jeff Lee
Jeff Lee's Avatar
I'd take a close look at valve springs
Jeff Lee 7494 D/S '70 AMX
Old 11-16-2013, 04:35 PM   #5
Ed Wright
Ed Wright's Avatar
I had that once with a car I had just put together. Ended up I had too much gear in it. First time out was at an altulitude track out in west Texas. Qualified 4th first time down the track. I was all impressed with myself until I got back home and didn't run any faster.
Bad air didn't bother it. Good air, it didn't care.
Ed Wright 4156 SS/JA
Old 11-16-2013, 05:13 PM   #6
blueboatcar
Its a 4000lb car with 4.88 gears in it
Old 11-16-2013, 04:33 PM   #7
442OLDS
442OLDS's Avatar
Liked 282 Times in 103 Posts
Talking Re: no change
Sounds like you have your throttle stop figured out pretty good.
If you can run 12.0's in 4200 ft of air,I would say you should be able to get close to setting the record at a fast track when you figure out your issue.
