Old 11-04-2013, 07:33 AM   #1
brent flynn
brent flynn's Avatar
Default Re: Update E-F/SA Bird Build...
Brent,,, do you plan on taking the car to Columbus,, the 1st weekend in May for the inaugural Northern Class Nationals? It should be on every racers' bucket list for next spring. If so,, I hope to meet you there,, take care.
Danny Durham
Hey Danny... I will have to see... Is a top 128 deal? Or an all run? Sounds like fun... If i can get it to the INdy Divisional, with no major problems, i might just have to make that one...its only 3hrs away from me
Old 11-04-2013, 04:15 PM   #2
Geerhead55
Liked 5 Times in 5 Posts
Wink Re: Update E-F/SA Bird Build...
If they do it this time around like it was run in 2001 at Byron,, they had, I believe 186 stockers on the property,, and I forget how many Superstockers, which is why many referred to it as the "Woodstock" of class racing.
Nitro Joe can correct me on this if I'm off on the count,, but it was a memorable event that I'll always be glad I flew out to see it. Take care.
Danny Durham
Old 11-05-2013, 07:42 AM   #3
brent flynn
Sounds like a good time... If i can make it, i will...Thanks!
Old 12-29-2013, 07:06 PM   #4
brent flynn
Finally finished wiring the MSD 6AL/2step/Blaster2 Coil up today. Got it running, set timing 34*, sounds real good...just got to tidy up some of the wires, that were there before i hooked it up. Anyone running a the same parts, and are the Blaster2 coils problematic? And should i have mounted it straight up and down? Thoughts?
Old 12-29-2013, 07:59 PM   #5
brent flynn
Im already hearing that i should mount coil straight up... no biggie, will correct that...
Old 01-17-2014, 07:21 PM   #6
brent flynn
Remounted my coil, upright... Soon as time allows, im removing heater box and adding delete plate, and then will remount on firewall... About to get my heads back... Degreed cam this past Monday eve.... gettin closer! Making plans to send my converter in , to get restalled...
Old 01-17-2014, 07:39 PM   #7
Dave Ribeiro
Liked 56 Times in 27 Posts
Thumbs up Re: Update E-F/SA Bird Build...
Brent,
Glad you fixed the coil, looks much better than before ... Lookin Good !!!
Dave Ribeiro 1033 STK
