Liked 20 Times in 16 Posts
Greg,
Thanks for the video. This info can be very helpful for many. I do have a question which is: You suggest to mark the beginning of the run when you come off the two step. I have been setting it at the first move of the drive shaft. My thought is that is the first movement of the car which is braking the beam on the track timer. If we are comparing data to our time slip would that not be the starting point?
Drew Wonderly SST 159 |
#2 | |
Liked 91 Times in 15 Posts
Don Eckel 1985 COMP |
#3 | |
Good point. I agree the first G meter movement may be the way to go. Let's see what others have to say.
Liked 19 Times in 4 Posts
I agree with Mr. Eckel...g meter to set start time
TURKMAN 4002 Stock, 4002 Super Stock |
Liked 886 Times in 238 Posts
When using the 8 magnet driveshaft collar on cars with numerically low rear gears ,I find the driveshaft and g-meter readings are very close.
On my car with a 4.30 rear gear there is about a .009 second difference. I'm sure gear ratio and car weight and shock settings will greatly effect the time difference, but the 8 magnet collar gives much better resolution of the driveshaft rpm. I noticed a huge difference between my driveshaft readings at Lebanon Valley and ones on a graph recorded with 2 magnets. Non throttle stop cars probably don't need this resolution ,but for a car running the .90 index's it's invaluable.
#6 | |
Liked 15 Times in 2 Posts
All good points. To SST159 there is no way to get any of the timing system info into a data log so we use some item in the car to start the run.
Here is what I think on the subject: - As mention above, unless you have a 8 magnet collar, I would not recommend using the DS movement for the start point. - Yes the G-meter is my #1 recommendation for the start point. - I sometimes use the RPM jump when TB releases because it's a bit easier (that was the reason in the vid) and it really is the mechanical beginning of the run. If the valve body, or TB solenoid, is not releasing exactly the same this is how you see it. - It's important to remember that this is not a permanent change to the log file - you can reset the start point at a later time. - Sometimes if I am overlaying more than two runs I will purposely offset the start in the runs so I can see overall picture better. |
#8 | |
I think for my purpose, the G meter may be sufficient to start the run. In the mean time I should look into the availability of an eight magnet collar. In the long run that sounds like the way to go. I cannot remember, however I believe my current collar has 4 magnets. Thanks for the input and suggestions.
