Guest
Posts: n/a
Liked 367 Times in 122 Posts
SWEET! I have one of those in my kitchen right now! Wonder if momma will miss it?? LOL! How much was that worth Dan? As quirky as these things seem I wouldn't be surprised if it picked you up a dime.
Liked 69 Times in 33 Posts
Dan, I'm not trying to toss any "garbage" your way, but is that legal in Pure Stock? In the past traditional stockers have had "non-OEM style" air filter bases questioned by Tech (at NHRA events at least), and I would think Pure Stocker rules would be even more restrictive. Don't shoot the messenger; just trying to avoid a spike in the sale of garbage disposal parts followed by a bunch of Pure Stockers being told to take them off.
#4 | |
Liked 184 Times in 113 Posts
Having drivability issues with mine. Want to make Lakeland too by taking the Auto Train to Sanford. You made the better choice. There are a whole lot of local guys my converter would work better for. FWIW.. with a IHRA approves cam you could have gone to 4200 stall. However if the 3800 stall if it flashes to 4600 you will be fine.. Dan Last edited by Dan Fahey; 10-10-2013 at 12:47 PM. |
Guest
Posts: n/a
B/PS? Who in the world would want to run that?
![]() Contact Mark Kent at GM about the cam specs. IHRA didn't have any for our car so we emailed him and he was kind enough to send us the OEM #s. I then sent those to Mike Baker and he approved the car for Pure Stock. Then gave those numbers to Bullet and they ground us a nice cam. With changing the cam and adding 1 & 7/8" headers we picked up more than 5 tenths. Also, don't be afraid to put a converter and gear in it. We have a Yank SS4000 because I found one almost new for about half of what they cost. It's a great converter but it's a street converter. When I get ambitious I'm going to try to get it loosened up to 5000. We also put a 3.90 gear in the car because it was a DD at the time. They only go to a 4.10 on the gear for these cars and I wish I had that. We run a 28" tire. I believe with a 5000 TC and a 4.10 gear I could pick up even more. If I had an LT1 car (and I have had those) I wouldn't hesitate going with a 5000 converter and a 4.56 gear with a 28" tire. Where are you located? Scott Last edited by Tar Heel; 10-10-2013 at 12:39 PM. |
Liked 35 Times in 6 Posts
Thanks for the information. Would you still go with a 5000 converter if the engine redline is 5700? I know there is more to it than say a 5000 stall. We used to run 5200 8" converters in j/sa firebird with a 305. I guess it was no different back then! I totally agree with the gearing and that high of a stall.
When you got the camshaft from Bullet, What was different about it? Duration? CL? Oh yea, I'm in ohio. Last edited by russellauto1; 10-10-2013 at 01:21 PM. |
#7 | |
Guest
Posts: n/a
I'd have to look at my cam card but the lift and duration were the same as stock and I do recall the CL being different. I can honestly say with the new cam down low the car is a different animal. Our best 60' (with "only" the 3.90 gear and a DOT drag radial) is 1.53 in poor DA with a crappy prepped track. When you call Bullet ask for their Stock Eliminator cam guy John. And yes, they'll get it to run past 5700 so I would go with that loose of a stall. Scott |
#8 | |
#9 | |
Guest
Posts: n/a
Is Jeremy Preston who you're speaking of? We still have AC, legal plates, etc. on ours and could easily drive it out the gate and home if needed. Scott Last edited by Tar Heel; 10-10-2013 at 07:11 PM. |
