Old 09-21-2013, 07:31 PM   #61
John Nechiporchik
Liked 13 Times in 7 Posts
Default Re: Intermittent no start condition
I have done the test you described....Sprayed some starting fluid into the throttle body.....it started and ran for about one or two seconds.
John Nechiporchik is offline   Reply With Quote
Old 09-21-2013, 07:33 PM   #62
ss3011
ss3011's Avatar
Liked 239 Times in 114 Posts
Thanks for the info John. Now we know that none of the trigger electronics in the Opti-Spark have anything to do with your no start condition. It is so hard to track down intermittent problems. Since you have spark it is a good bet that you have a connection or wiring problem. Usually ECU's either work or they don't. Have you tried disconnecting the main injector connector and reconnecting it ? Most all the terminals are crimp connectors. If you know which wires are the power leads, then when you have a no-start condition leave the power on and probe to see if indeed you have the 12v power to the injectors. The ECU provides the ground to pulse the injectors. If you don't have it set up for sequential , which I don't think you do, because the Opti-Spark trigger is not hooked up. Then your system fires 4 injectors at once. Everytime the ECU sees 4 pulses from the crank trigger it fires a set of 4 injectors, usually bank to bank. It doesn't know when, since it has no particular cylinder reference, just every 4 pulses. Your ignition works, so the ECU is getting the pulses. If the injectors aren't firing then check the simple things first, like the connector connections, 12V supply to the harness, etc. You will figure it out, that DFI system is very reliable.
ss3011 is online now   Reply With Quote
Old 09-21-2013, 07:36 PM   #63
Rich Biebel
Rich Biebel's Avatar
Liked 544 Times in 213 Posts
I agree 100% with this post.....and this advice is spot on....
Rich Biebel
S/C 1479
Stock 147R
Old 09-22-2013, 10:53 AM   #64
John Nechiporchik
SS3011 and Rich,
This morning I read your post again and went back to the drawing board. I have the wire pin out list and started looking for the power feed circuits(+12v) to the ECU. I found a power feed that had an in-line fuse in a Packard fuse holder with a cover on it. I looked at this previously and thought it was a connector....not a fuse. Well, I popped the cover and found a blown 30 amp fuse. Replaced the fuse, car fired right up. I started it 7 times and each time it fired up.
Recall this started as an intermittent problem, then a full blown no start. So, the fuse got the car running again. I'm hopeful that running the ground back to the negative battery lug solves the intermittent issue. I will continue to start it randomly throughout the day and validate that the problem is solved.
I will also replace the coil as the MSD 8261 seems to have a history of problems.
I hope this is the last I need to post on this issue.
I want to say "Thank You" to all of the help you guys have given me as we walked through this thing.
I learned more about this electronic fuel injection system in a week then I thought I would ever learn!!!
Old 09-22-2013, 01:53 PM   #65
Rich Biebel
Great news John and I was pretty sure you would find something if you dug into the wire connections.
I work on electrical equipment everyday.....Nothing worse than an intermittent problem but I get them all the time...
We have a little Joke saying at work that covers this....
A good visual inspection will often reveal the problem...
I work on Miller Welders and that saying comes from them and has always been true...
With all the electronics these days that is not so true anymore but you have to start with the basics....
I am glad something I wrote may have helped you
I kind of wish I had my Firebird back....I really loved the wheelies.....LOL
Rich Biebel
S/C 1479
Stock 147R
Old 09-22-2013, 06:12 PM   #66
buzzinhalfdozen
Liked 11 Times in 8 Posts
Good deal John, glad you found it.
Joe Buchanan SS/BX 3117
Old 09-30-2013, 11:19 AM   #67
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Originally Posted by buzzinhalfdozen View Post
Mike, make a small jumper wire, disconnect your crank trigger, with power on to MSD and a spark tester or an old spark plug on the coil wire (grounded of course) momentarily touch the jumper across the 2 terminals of the crank sensor harness. You should get a spark from the coil each time you remove the jumper.Other than that I believe you should see 800-900 ohms from the sensor, I agree with Rich crank sensors are very robust and do rarely fail though they're often blamed. I think MSD has a trouble shooting section on their web site but don't remember for sure.I'd bet someone you know has a MSD ignition tester, invaluable piece of equipment well worth the investment. BTW stay clear if the coils terminals as the have very high voltage potential DO NOT lay your arm against them (ask me how I know). Good luck. Joe
I got mine started over the weekend. It was the pick up coil on the crank trigger. I did the jumper check and had spark. Changed out the pick up and she fired right up. Thanks for the tip on how to check that. Lots of good advice on this site!! Thanks again guys.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 10-01-2013, 09:19 AM   #68
buzzinhalfdozen
Mike, happy to help, that's what makes this site so great...lot's of good info. I personally love the tech discussions, always seem to learn something.
Old 10-01-2013, 01:23 PM   #69
Bobby DiDomenico
Liked 101 Times in 52 Posts
Originally Posted by John Nechiporchik View Post
SS3011 and Rich,
John,
Been following this with some interest after talking with a guy at a cruise night near me who installed a tuned port Chevy into his Avanti and he mentioned some issues he was having. That 30 amp fuse is pretty big, maybe see if you have a loose connection somewhere which popped it when contact was re-established. A 30 amp breaker would reset but you'd need to have some type of indication it tripped, such as a light which illuminates when that circuit becomes open so you would be aware of potential issues.
Old 10-02-2013, 11:01 AM   #70
John Nechiporchik
Bobby, After I got the car running, I tried to carefully reconstruct the test process that I followed and determined the following: The intermittent condition turned into a 100% no start condition as I was testing the various components. When I got to testing the injector connector, the homemade noid light ( a line lock light with two 6" leads with the correct terminals) .......I plugged one lead into the connector and the second lead momentarily touched the intake, resulting in a quick spark. I subsequently realized that this spark was the indicator that the fuse blew.
So, I'm pretty confident that I have isolated the root cause of the blown fuse.
Also, I believe isolating the ECU ground circuit from the stud with 6 ground leads stacke up (ran ground to - battery lug) took care of the intermittent condition. This was based on advice from an Accell service rep.
Thanks for your input.
