#18 |
Liked 13 Times in 7 Posts
Rich, I did test the coil immediately after experiencing the no-start condition. I placed the spark tester between the coil and the coil wire. Spark was there. I did not, however, test it on the other side of the coil wire (your process). I will do that tomorrow. That would eliminate or validate a bad coil wire. I will go through all the wiring this weekend....after I do the noid test.
I will find a noid between now and the weekend. Thanks. |
