Old 09-10-2013, 09:52 PM   #4
D. Hake 4459
D. Hake 4459's Avatar
Liked 2 Times in 1 Post
Default Re: two step for starting line and burnout
My burnout rpm is barely higher than converter flash. I start the burnout in 2nd gear, bump the limiter, put in high, bump the limiter, then hold it just under that for a couple seconds and drive out of the water. My piston to valve clearance is pretty tight so I don't want rev it too high in the water and hurt it. Is a 3 step legal in stock eliminator? I have a 2 step and a 3 step already.
D. Hake 4459 is offline   Reply With Quote
