That's not rust eating away at the rivets. You can cleary see the blueish purple heat discoloring around the pinch weld holes from a plasma torch cut. Mothe Mopar pinch welded the VIN tags onto the drivers side door posts in 1965 ...special headed riveted VIN tags appeared later on the driver's side lower corner of the dash. I smell a rat.
