Old 06-21-2013, 12:59 AM   #1
Phillip marvetz
Phillip marvetz's Avatar
Default Re: BBM/Hemi stocker oil pan
http://www.ebay.com/itm/MoPar-Oil-Pa...9f26e9&vxp=mtr
2009 V/SA Record Holder
Old 06-21-2013, 02:20 PM   #2
Tom Nolan
Liked 64 Times in 11 Posts
Classification guide only gives 2 different part numbers, you cant use just any stock looking pan can you?
Tom Nolan is offline   Reply With Quote
Old 06-24-2013, 07:42 PM   #3
Chris DeGidio
Chris DeGidio's Avatar
Liked 2 Times in 2 Posts
Originally Posted by Phillip marvetz View Post
That style pan won't fit in a A-body car,but I really like the Moroso pan,it fits any Mopar and it's made well.
Nautilus Racing
Chris DeGidio is offline   Reply With Quote
Old 06-25-2013, 10:54 PM   #4
Phillip marvetz
I'm pretty sure Tom is putting a early B body together and it will fit if you notch the K member like Mark said.
Old 06-26-2013, 03:26 PM   #5
Chris DeGidio
Phil,
I posted the info to help someone that might read the thread,and also experience from using the E-body pan. The Moroso pan fits allcars without notching the K-member.
Nautilus Racing
Old 06-26-2013, 09:09 PM   #6
Phillip marvetz
Chris,
It's a real pain in the ***** to check bearings unless you notch the K member and the bearings need to be checked quite often. I guess if you don't have one of these cars you probably are not aware of that though.
The pan you are recommending is listed as a 4 quart capacity. Do you think that is wise considering the RPM Tom is going to be turning? This is not a warmed over 440 in a street driven Dart.
Tom, If you use one of those pans you are asking for trouble. Take a look at the factory Nascar pans, They are available on ebay once in awhile. You are going to want to notch the K member for clearance no matter which pan you end up buying.
Do not buy one from my buddy in Waldo Florida, He will sell you the ebay one I listed and charge you $300.00 for it. Been there done that. Good luck on your project.
Old 06-30-2013, 05:28 PM   #7
Chris DeGidio
Yep,I have a B-body car and a a-body with 440's.I can pull both pans by dropping the idler arm. Moroso has a 5 qt Hemi pan as does Milodon.
Nautilus Racing
Old 07-03-2013, 02:24 AM   #8
Phillip marvetz
What year is your B Body Chris?
