Old 06-18-2013, 07:49 PM   #1
Ed McLawhorn Jr.
Liked 19 Times in 17 Posts
Default Re: rod bearings recommendation
Danny,
It has been a long time since it was run. It will also be a slow process coming back. Not sure when will complete, but you got to start somewhere.
And you are correct, the main goal is to have some fun!
Ed
Ed McLawhorn Jr. is offline   Reply With Quote
Old 06-18-2013, 09:24 PM   #2
Lew Silverman
Lew Silverman's Avatar
Liked 129 Times in 59 Posts
And it appears that the number "2993" is the rod journal diameter (2.2993), Vandervell Set VP768.
Lew Silverman #2070
"The Wagon Master" N/SA
Old 06-18-2013, 10:30 PM   #3
Adger Smith
Liked 880 Times in 311 Posts
Clevite gobbled up Vandy bearing Co. In the past you could get the same Vandy material you just add V to the Clevite bearing part number and dropping the 'H" or "P".. For instance CB 745H becomes CB745V. BTW: CB745 is the SJ Chevy number. The "V" material formula is a little softer and more forgiving than the harder "H". It works well in applications that the crank flexes a lot and the oil film gets so thin the bearing bumps the crank. IE: 282-327 SJ Engines.
Adger Smith (Former SS)
