Old 08-24-2007, 10:24 AM   #2
Mike Pearson
Mike Pearson's Avatar
Liked 1,987 Times in 599 Posts
Default Re: Lower a arm bump stops
I use a polyurethane traction bar snubber on both the upper and lower A arms on my 68 Camaro for travel limiters. the nut and bolt will be to rigid and will mprobably unload the rear tires when the car landshard and hits the stops on the lower A-arm. The use of a good double adjustable shock on the early camaro's is the best setup and the only way to really control the bouncing after leaving with the wheels in the air. also look at your inner wheel wells and make sure the tires are not rubbing when the car comes down from a wheelstand. This condition will make the car inconsistent.
Mike
Mike Pearson 2485 SS
