Old 05-29-2013, 08:37 PM   #1
Grant Eldridge
Grant Eldridge's Avatar
Default Re: 1970 Nova question.... rear fenders for stocker
On my 1970 Nova, using 30"x9 Hoosier Radials we used a 5.5" backspacing on a 10" rim. We did, however, need to do some "massaging" on the inner closest points with a sledge hammer. Also, we had to ensure that the rear end was perfectly centered and correct it to get equal spacing from side to side. As previously mentioned, also had to roll up the lip so it does require some attention to avoid rubbing, but will fit. We had also used a shortened full size 12 bolt housing, so your housing could vary slightly as to width. Best to borrow a wheel/tire and test fit if possible before ordering your wheels
Grant
Grant Eldridge is offline   Reply With Quote
Old 05-30-2013, 02:15 PM   #2
glen myers
glen myers's Avatar
Liked 2 Times in 2 Posts
Why on earth yould you want to know???
ha ha
glen myers is offline   Reply With Quote
Old 06-02-2013, 08:02 PM   #3
gbur
ha ha
Let the boys be boys Glen
gbur is offline   Reply With Quote
