Liked 984 Times in 198 Posts
The Pontiac-Oakland car museum here in Downtown Pontiac is looking for a 389 crankshaft for a 59 389 tri power motor they are building for a display.They are wondering if a later year 326-455 crank would fit in the block.they just need the front snout to be compatible for balancer,and pulley mounting.Can anyone shed some light on this? thanks
Yea...even a 326-400 crank will fit right in(same Main size, rod bearing size, and stroke... No , on the 421-455..
If they need one, i have crank, will sell ![]()
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() Last edited by brent flynn; 05-20-2013 at 10:10 PM. |
Nope.... 59- 66 use a different front snout than the 67 and newer
Liked 780 Times in 194 Posts
What Yac said
thanks for the info guys.I will look for a 59-66 crank.
Liked 184 Times in 113 Posts
What a Cranky Conversation !
I think the snout is shorter on the '59 era cranks, but i believe they will interchange... call 765 534-4140 Terry Spidel will be able to give you info on this...
1968 Bird/TRW 455/Home ported 13's, '70 Qjet,Holley Street Dominator manifold, Comp Solid FT, 10.817/122.30/1.440 Workin' on E/SA combo ![]() |
