Old 05-12-2013, 05:08 PM   #1
Robbie Welch
Liked 262 Times in 124 Posts
Default Top loader
What's the correct way to adjust shift linkage on a top loader. The trans seems a little hard to go into 2nd gear. This is a street car whit a 289. Thanks Robbie
Old 05-12-2013, 07:17 PM   #2
Mark Ugrich
Liked 71 Times in 38 Posts
Default Re: Top loader
Pin the shifter in neutral, then adjust the shift rods so the individual levers are in their neutral postion also.
Old 05-13-2013, 06:55 AM   #3
Robbie Welch
That's what I did, I'll go through it again and I'll also put new bushings in. Thanks Mark
Old 05-13-2013, 08:17 AM   #4
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 306 Times in 103 Posts
Usaully linkage adjustment effects you 2-3 or going through neutral,I'm guessing it's H pattern, try shifting really slow to 2nd, if shifts easier may be sycronizer starting to wear,if it's just a little wore may not grind yet,usaully a bad syncro will let slider and dogs scrape together on shift making scrape or gear grinding sound,be sure clutch is releasing good also that could cause but would most likely effect all shifts,also make sure linkage is not rubbing anything,also make sure shifter just don't need a litttle oiling up
Mike Taylor 3601
Old 05-14-2013, 06:44 PM   #5
Robbie Welch
Thanks Mike, the shift is a little hard going in to 2nd. I'll go through the adjustment and lube up the shifter and see if that helps. How hard are these things to rebuild? Robbie
Old 05-15-2013, 04:52 AM   #6
Mark Ugrich
Not too hard to rebuild at all Robbie, the rear output bearing can be stubborn at times,other than that pay close attention to the direction and location of the 1-2 and 3-4 syncro hubs and sliders.I'm sure there are many parts suppliers for the toploader,but I used David Kee transmissions the last time I rebuilt mine.
