#1 | |
Liked 130 Times in 42 Posts
Is the front and rear suspension nice and free to move with the shocks unbolted? This can cause a lot of grief if any thing is over tightened and hasn't been greased in a while. You're running a bias tire? Radials will need the rear extension loosened up more to work right like Todd mentioned. If will take a few hits to find the right settings on the shocks. Just keep adjusting until it responds. Some video would sure help, good luck! Last edited by Troy Henderson; 05-13-2013 at 01:26 PM. |
#2 | |
The last setting I used was full tight on compression and 8 clicks from tight on extension. I will keep adjusting one motion at a time until it starts to respond. THANK YOU for your help! |
#3 | |
