Old 04-25-2013, 09:10 AM   #1
Joe Toller
Liked 9 Times in 9 Posts
Default Re: Under the index for under a grand!
Anything special in the ignition system?
Old 04-25-2013, 09:48 AM   #2
Troy Henderson
Troy Henderson's Avatar
Liked 130 Times in 42 Posts
Cool thread, someone at Hod Rod magazine or similar should pick up this story for some good publicity.
Troy Henderson
Henderson Race Shop LLC 816-520-5389
www.hendersonraceshop.com
Troy Henderson is offline   Reply With Quote
Old 04-26-2013, 01:59 AM   #3
Jeff Lee
Jeff Lee's Avatar
Pontiacchuck asked 3 days ago...So what's the big secret here...how quick was the ET, how fast was the MPH? And how far under did it go? Unless I'm missing something here, that was the point of it all.
Jeff Lee 7494 D/S '70 AMX
Old 04-26-2013, 07:27 AM   #4
Curt Rees
Liked 251 Times in 51 Posts
Thumbs up Re: Under the index for under a grand!
Keep the suspense going, Billy! Gives us something to do every day!
#5457
Curt Rees
Curt Rees 5457 SS
Curt Rees is offline   Reply With Quote
Old 04-26-2013, 07:28 AM   #5
Billy Nees
Stock HEI with the mech advance locked. Cap, rotor, wires and coil that came on the car but I did put a good set of used plugs in it.
Billy Nees 1188 STK, SS
Old 04-26-2013, 09:47 AM   #6
Billy Nees
The Payoff;
I took it to "The Beav" on Sunday to see if this project was worth my while or a bust.
The excuses, first, I had trouble with the trans leaking on my first run and had to address that before I could go down the track again. Second, even though it was a good day, "The Beav" is not a fast track by any stretch of the imagination (Beardie, a little help). Third, I set the timing at 32* total and have no idea what jets are in the carb so what I'm saying is that I had no time at all to do any tuning. I wound up making 6 runs and all that I did was change the launch RPM and temperatures.
The asterik, "The Beav" is an IHRA track so that means that I get to run the IHRA index right? The last pass the car went a 15.159, 87 MPH on a 15.15 IHRA index. Oh yeah, it was 140 lbs. heavy and there was about a 6-8 MPH head wind.
I will be taking some weight out of it today and tomorrow and I'll be going back to "The Beav" on Sunday and doing some tuning.
So far I'm very happy with it. The converter works better that I thought it would and even though it's too tight and too heavy(it feels and sounds like a stick car with a 55 lb. wheel in it) it seems to let the motor work. It either has to make more power or it needs more gear but that's not happening with the 7.5 rear. The "junkyard" headers are too big and too short but 301 headers don't fall out of trees. I may put a set of my headers on it after a while to see how they work.
Curt, stay tuned, I'm just getting started on this. There will be updates. Any suggestions or comments(within the budget)?
Old 04-26-2013, 10:29 AM   #7
Mike Carr
Mike Carr's Avatar
Liked 83 Times in 37 Posts
Having been to, and raced, at Beaver Springs, I can attest to how slow it is.
First, it's up hill. If you sit in the waterbox, in neutral, and take your foot off the brakes, you will roll backwards.
2nd, it's altitude of sorts. I think physical elevations is 1,200' or so, in the hills of central PA.
I set the HF/SA record there in June 2004 in Billy's Sunbird. Record was 18.05. DA that day was close to 3,000' (would have to find my old logbooks for exact numbers). Two weeks later, I went to MIlan Michigan. Even though I didn't get points for re-setting my own record, my ego didn't want a -.55 record. SO, in warm, near 3,000' corrected elevation air again, I went 17.74 then 17.71 on the back-up, at Milan. No changes of any kind to the car at all (felt better that my record was now -.89 under. OBTW, I ran 17.59 (-1.01 under) at Budds Creek MD earlier that year, actually spinning the tires on worn out old slicks).
So, yes, Beaver IS slow compared to many tracks. Especially for slower, lower-powered cars.
Old 04-26-2013, 03:15 PM   #8
Ed Fernandez
Ed Fernandez's Avatar
Liked 100 Times in 45 Posts
Talking Re: Under the index for under a grand!
Not a bad light,for an old man.Put the Billy Tubes on it.Like you said,there's probably more in the fuel system.What size tire you running out back?And finally see if Bob will let you run from the finish line to the starting line,plenty of room to stop that bucket of bolts.Just some friendly suggestions.
Former NHRA #1945
Former IHRA #1945
T/SA
Old 04-26-2013, 03:32 PM   #9
Billy Nees
For most, purely entertainment. For some, hopefully a bit of knowledge. For a very select few, incentive!
Old 04-26-2013, 04:21 PM   #10
TGould
Liked 32 Times in 6 Posts
Hey Billy, take out .06-.08 for the head wind and correct the ET to sea level and your at or under the NHRA index. Now, for a certain down hill NE sea level track and a few of those 00 bulbs.
Tom
TGould is offline   Reply With Quote
