Old 04-22-2013, 01:24 PM   #1
FED 387
Liked 333 Times in 180 Posts
Default Re: Oil Filters?
Not positive but I seem to think that the P4529190 filter has a bypass of like 8-10 PSI and a flow rate of 28-30 GPM vs. the "stock type " Neon filter which has a bypass of like 25-30 PSI and a flow rate of only 7-9 GPM--probably why the pressure is coming up so low----less restricton and more oil flowing(volume) ---put a wix 51515R on it and see what happens they are really the way to go---otherwise put a Peterson in line filter on the inner fender but then you hafta run braided line and all----FED387
