Old 04-17-2013, 01:33 PM   #15
FED 387
Liked 333 Times in 180 Posts
Default Re: Fuel Pump Recommendation
Bricki--also forgot to mention since you are using a bypass/return line system the relationship of the placement between the pick up line and the bypass line is critical also to prevent aeration or foaming of the fuel--FED387
