Old 03-26-2013, 11:51 AM   #21
dannyboy
dannyboy's Avatar
Liked 42 Times in 10 Posts
Default Re: Interesting new Rule coming in 2014
NASCAR's exhaust systems are bolted in at least 3 places from header to exit at side of car. Tab on collector and pipes have spring with washer and nut to allow for vibration. This was the way I did it a few years back and passed tech many times.
dannyboy is offline   Reply With Quote
Old 03-26-2013, 11:57 AM   #22
BBF67
Liked 8 Times in 4 Posts
When was the last time a techman actually got down and looked under your car?
BBF67 is offline   Reply With Quote
Old 03-26-2013, 12:05 PM   #23
dannyboy
dannyboy's Avatar
In NASCAR you put the car on jack stands and provide them with a creeper.
Old 03-26-2013, 01:16 PM   #24
FED 387
Liked 333 Times in 180 Posts
Question Re: Interesting new Rule coming in 2014
Mark --go get em--will be following your results---by the way is this EVERY car in EVERY class that does not have fully welded headers/collectors???- eventually NHRA will have tethers on most anything if ya let em get away with it--FED387
Old 03-26-2013, 01:42 PM   #25
KRatcliff
Liked 534 Times in 143 Posts
The staging lanes just need a nut checker like the golfers have a ball washer.
KRatcliff is offline   Reply With Quote
Old 03-26-2013, 02:17 PM   #26
SSDiv6
Liked 1,583 Times in 582 Posts
The spring system and the long bolt are currently use in NASCAR.
Here are options:
http://www.spdexhaust.com/pdfs/AccPDFs/Retainers.pdf
Old 03-26-2013, 02:19 PM   #27
SSDiv6
Are you volunteering?
...or wear a protection cup like baseball and martial arts fighters do...
Old 03-26-2013, 02:25 PM   #28
KRatcliff
I am not shy and have no problem with that. Just be aware that I sanitize my hands by soaking them in the cooler.
Old 03-26-2013, 03:11 PM   #29
SSDiv6
Originally Posted by A56 View Post
Ironicly , I have just put together a collectors this morning with one A/B ovelapping tab kit, one spring tab kit, and one Wing style tab kit. Im going to ask Bruce if we can use the Wing style tab as the final safety device instead of the Lokar system. We all have either spring tabs or A/B tabs. The Wing tab kit would work as a final safety device, but this up to NHRA. Im bringing this collector with tab kits installed to Vegas with me, so wish me luck .... im goin in ....
Mark Lelchook
F/SA D/ED
From a technical perspective, due to the amount of the tab area that is welded to both the collector and header, wing style tab and the spring style tab would be the strongest.
Old 03-26-2013, 04:59 PM   #30
FED 387
I'm no techie but what do you think of the possibility of all the welds/bolts/springs/tabs/wing nuts in Mark's design failing ? REMOTE comes to mind !!!! The tether system as it appears totally eliminates "any" possibility of the exhaust system coming loose when installed & maintained properly and falling on the track that is the argument NHRA is probably gonna use whereas any one or all of Marks fastening devices "could" fail ( highly unlike that ALL would) and let the exhaust loose on the track--FED387
