#21 |
Liked 42 Times in 10 Posts
NASCAR's exhaust systems are bolted in at least 3 places from header to exit at side of car. Tab on collector and pipes have spring with washer and nut to allow for vibration. This was the way I did it a few years back and passed tech many times.
#22 |
Liked 8 Times in 4 Posts
When was the last time a techman actually got down and looked under your car?
#23 |
In NASCAR you put the car on jack stands and provide them with a creeper.
#24 |
Liked 333 Times in 180 Posts
Mark --go get em--will be following your results---by the way is this EVERY car in EVERY class that does not have fully welded headers/collectors???- eventually NHRA will have tethers on most anything if ya let em get away with it--FED387
#25 |
Liked 534 Times in 143 Posts
The staging lanes just need a nut checker like the golfers have a ball washer.
#26 |
The spring system and the long bolt are currently use in NASCAR.
Here are options: http://www.spdexhaust.com/pdfs/AccPDFs/Retainers.pdf |
#27 |
#28 |
#29 | |
#30 |
I'm no techie but what do you think of the possibility of all the welds/bolts/springs/tabs/wing nuts in Mark's design failing ? REMOTE comes to mind !!!! The tether system as it appears totally eliminates "any" possibility of the exhaust system coming loose when installed & maintained properly and falling on the track that is the argument NHRA is probably gonna use whereas any one or all of Marks fastening devices "could" fail ( highly unlike that ALL would) and let the exhaust loose on the track--FED387
