Liked 10 Times in 7 Posts
Any recommendations on a repair facility for VDO Play back Tach?
Liked 333 Times in 180 Posts
ya might try Ronnie Smith--- I think he comes on here from time to time--Either he or his dad used to work for VDO might be able to help you
Liked 535 Times in 110 Posts
What's wrong with it? I've had one of those for years and love it. You do have to re-calibrate it once in a while, but it's fairly easy to do.
Jim Kaekel 3836 STK |
Nichols Speedo & Instrument, Greensboro NC---
Thanks for the info, Jim it doesn't come on at all. Seems dead?
I'll reach out to Dad and see if he knows of someone or somewhere to have it repaired.
Liked 13 Times in 7 Posts
You do know that you need an off/on switch so when you turn off the ignition above (I think it's 3000RPM's) it will reset to zero. You can turn the tack off with the switch and it will reset. I love mine and I bought a second one for my second car. Make sure that you put tin foil aroung the wires, it doesn't like outside interefence.
Richard Grant 4988 STK |
Dad was told that National Speedometer in Charlotte repairs them. However, I did a quick Google search and could not come up with an address or web email for them. I did see a result for them in Las Vegas. I presume they are one and the same.
Hope this helps. |
I'll check out these leads
