Old 03-21-2013, 01:20 PM   #1
Glenn Briglio
Glenn Briglio's Avatar
Liked 970 Times in 308 Posts
Default Re: Hold down clamp
Originally Posted by Ron Gusack View Post
Rotor phasing isn't necessary unless the car has EFI or a crank trigger, right? I've only done that when I was running a crank trigger.
Rotor phasing should always be checked and corrected no matter what ignition system is used.
Old 03-21-2013, 03:09 PM   #2
Ron Gusack
Ron Gusack's Avatar
Liked 7 Times in 6 Posts
I pulled the distributor out of it yesterday and I first lined up the rotor with number one on the cap. I noticed that the balancer was closer to 50 than it was to the 38 that the timing light reads with the engine running. I guess I need to get an adjustable rotor and a new cap.
Ron Gusack is offline   Reply With Quote
Old 03-21-2013, 03:26 PM   #3
FED 387
Liked 332 Times in 180 Posts
sounds like the dist might be of a tooth ??? might hafta move it back or forth to get it lined up properly--also acheck fore wear on the dist gear see if its worn --FED387
Old 03-21-2013, 06:53 PM   #4
Ron Gusack
Ron Gusack's Avatar
The timing was at 38 then I put the rotor in line with number 1 on the cap then I noticed how far off the balancer was.
Old 03-21-2013, 07:14 PM   #5
FED 387
I'd then check the timing chain/gears-ya got the advance locked ???--with the engine running when you check the timing does the timing tend to retard ??? you hafta check it at above 3500 rpm so that all the slop and the torsional twist is outta the chain--- as the rpm goes up to say 6-7000 it is gonna retard so that is where yoou need to be checking it---static timing is gonna be close but not the same as a running engine
