Old 03-12-2013, 09:59 PM   #161
David Barton
Sponsor
Default Re: Hemi Head Ruling
Stewart, that's not what I meant. I realize the rules for sections like the carburetors cross over. I was saying that if a section is written in Super Stock, it replaces whatever it said in Stock. If that wasn't the case then nobody can run head studs either. It says in Stock, cylinder head studs prohibited, and nothing in Super Stock. This is no different than the valve cover bolt hole issue. But like you said, the key is enforcement. Whatever the rules are they need to be the same for everyone.
This whole thread was started because I wanted to shed some light on the situation. I sat around for months while guys were accusing us of cheating and ruining the class. I want nothing more than to protect the rules and play fair. We have been cutting into the valve cover bolt holes forever and have been through teardown enough times to fill our wall full of records. And not once did I ever hear anything from anybody about valve cover bolt holes. If it was illegal you would think somebody in the last few decades would have said something.
Either way we're moving on and going racing. We're super excited to go down South and support the cause while others just use it as another excuse to not go racing.
David Barton is offline   Reply With Quote
Old 03-12-2013, 11:25 PM   #162
Dinsdale
Dinsdale's Avatar
Liked 6 Times in 2 Posts
As far as I can tell it was illegal right up until the "EXCEPT AH" was recently added.
NHRA RULE AMMENDMENTS MADE FROM THE END OF THE 2012 SEASON TO THE BEGINNING OF THE 2013 SEASON
2 3
Super Stock cylinder-head volumes as listed on www.NHRARacer.com. Regardless of the poured volume measurement, any modifications to intake or exhaust runners prohibited. Any evidence of modifications from the original castings will be grounds for disqualifications as determined by NHRA in NHRA’s sole and absolute discretion. Any aftermarket steel valve permitted, must retain stock head and stem diameters. Only engines OEM-equipped with sodium-filled valves may use sodium-filled replacement valves. Titanium prohibited. Hardened keepers permitted. Lash caps prohibited. Valve-diameter tolerance: +.005- inch or -.015-inch from NHRA Specs. The following are prohibited: spark-plug adapters; cylinder-head studs; any grinding in ports or combustion chambers; removal of any flashings; sandblasting or any other modification to cylinder head; any film coating of intake and exhaust runners; any film coating of combustion chamber. Runners and combustion chamber must retain OEM appearance. Final acceptance as determined by NHRA in NHRA’s sole and absolute discretion.
Intake side of head may not be cut into any part of valve cover bolt holes. Valve cover bolt holes must remain unaltered and in their original location.
Heat riser passage may be blocked from intake manifold side of cylinder head. Blocking passage down in valve pocket prohibited. The following are permitted: polylocks, jam nuts, screw-in larger-diameter rocker studs or pinned studs, bronze-wall valve guides. Valve spring umbrellas optional. Cylinder head may have all of the seats replaced. Any valve job permitted,Oringing prohibited. Exhaust plates prohibited.
Dale Posnick
Dinsdale is offline   Reply With Quote
Old 03-15-2013, 07:16 PM   #163
bubski
Liked 165 Times in 60 Posts
we didn't know about any of these rules. We only know about everything else and who's cheating besides us. Hood scoop mods, mill intake flange as much as possible, maybe C clamp manifold to block! and the list goes on and on. If the people guilty of this would read the rule book as much as they respond to this thread there would be no thread on this. Stock and Superstock used to mean something at one time. The credibility of the class and most in it are gone. What a shame.
bubski is offline   Reply With Quote
Old 03-28-2013, 06:22 PM   #164
Spyphish
Liked 679 Times in 180 Posts
Two Scoop: From NHRA today
Racers to be able to easily obtain factory correct components which will be tuned and modified within existing rules (not redesigned) to maximize performance capability
For your convenience I have it in French
Coureurs Ã* pouvoir obtenir facilement les composants corrects d'usine qui seront accordés et modifiés dans des règles existantes (non remodelées) pour maximiser la capacité de représentation
Me and the Robinsons are HAPPY HAPPY HAPPY
