Old 02-08-2013, 04:21 PM   #11
Jeff Lee
Jeff Lee's Avatar
Default Re: How a Cal-track works
Shocks dampen movement .
They have nothing to do with suspending the car.
And that's what I meant without getting into the action of the shock. The rear of the springs does "suspend" the rear of the car. The "suspension" as I called it is the act of controlling the movement of the rear of the car suspended by a leaf spring in this case.
Jeff Lee 7494 D/S '70 AMX
Old 02-08-2013, 10:40 PM   #12
gmonde
gmonde's Avatar
Liked 165 Times in 59 Posts
you really cant say that its compared to a ladder bar ,or even a slapper bar ,,, it works more like a canter lever ,,,as the power is applied to the drive shaft the rear begins to rotate, at that point the lever action is moved to the pivot bell crank of the cal track witch loads the front of the spring where flexing takes place the most ,, even cars with big horse power the body has minimal separation from the tire ,,,it gives the rear a chance to rotate and hit the tire with out the shock of a slapper bar,not as solid as a ladder bar ,,, great design in my opinion ,, I am used to making my own stuff but ,it works gmonde
Old 02-08-2013, 10:41 PM   #13
Barry Polley
Guest
Posts: n/a
Barry, I'm still going with the ladder bar. I see the lower link that pushes, but I fail to see the upper link that will pull.
If I might clarify, I see the Cal-trac as a sophisticated form of a slapper bar, better able to control spring wrap up..thereby acting as a ladder bar.
Mark. To point I agree but...In my thinking... The front spring section is a link correct? From the housing to a pivot point (spring eye?. The lower CT section is also a link, correct? If it were all connected (ladder bar) at some point I would agree but it does not. In any case they work GREAT!
Old 02-09-2013, 01:47 AM   #14
Jeff Lee
Jeff Lee's Avatar
Trivia: Competition Engineering made the "slide-a-link" back in 1972 or so. A friend of mine has them on his '72 Demon 340 G/S (?) that hasn't changed since he built it from a new car in 1972. Based on that, I'm under the impression John Calvert borrowed the concept and improved on it by eliminating the soft spot in the middle of the bar.
Which begs the question; which version is better? Personally, I see no use for the urethane shock absorber in the middle of the bar. But I see there are some real fans of the design. It would be an interesting test on the same car. Anybody here try testing the two?
Old 02-09-2013, 02:56 AM   #15
Nope..Don't think so.
Semantics aside, I'd say they constitute one link, all inclusive.
The "missing link" would have to be above the axle center line on the housing to function like a true 4 link.
Old 02-09-2013, 11:55 AM   #16
George Mirza
Jeff,
That would be an interesting test. I do know of one racer who switched for the slide a link to the Cal tracs and saw a major improvement.
I think the difference between the two is the slide a link will work with a steel multi leaf spring, where a Cal Trac works best with a mono leaf. From what I've seen, I'm yet to see a car with multi leaf srpings work like one with a mono leaf when using the Cal Trac set up. But I've seen some good working cars using Slide a links and multi leaf springs.
George (still using SS springs)
George Mirza is offline   Reply With Quote
Old 02-09-2013, 12:35 PM   #17
B Parker
Liked 2,336 Times in 464 Posts
Jeff the opposite is true. Cal Tracs came before slide o link. I had gone threw Moroso when they were designing the slide o link. Guess what was lying on the table. Are you sure your friend didn't have the Steve Hanby set up. Barry
Old 02-09-2013, 12:41 PM   #18
Lee Valentine
Liked 319 Times in 68 Posts
Autofab in Maryland had a setup like Cal - Tracs in the late 80's early 90's I had them on my E/SA 68 Camaro with fiberglass Mono - Leafs.
Lee Valentine 1661 STK
Old 02-09-2013, 02:48 PM   #19
Tom Goldman
Tom Goldman's Avatar
Liked 883 Times in 237 Posts
They all owe their basic design to the ET Traction Master bars.
I had these on my first car in '69 , and they were around long before that !
One of my Uncles' had a set on his C/A '47 Ford in the early '60's
The newer bars have refined the adjustability and function, but the basic concept belongs to ET.
Old 02-09-2013, 06:22 PM   #20
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
thanks for the pic!
i'd heard of 'em but never seen one...how'd they work?
plan is (on my rambler) to try cal-tracs, slappers and just clamping the springs...this gives me one more thing to try
