Old 02-01-2013, 01:30 AM   #1
69Cobra
Liked 2 Times in 2 Posts
Default Re: O-Ring grooves in head...
Originally Posted by bill dedman View Post
Can anybody recommend a machine shop trhat could cut O-Ring groovrs into an inline, six-cylinder cast iron head in my area (centrtal Arkansas)? This thing weighs 84 pounds and I don't really want to have to pay a king's ransom in shipping on it if I can avoid it.
Any help will be appreciated.
Bill, in Conway, Arkansas
PM Jeff Colvert on the forum here. I'm sure he could hook you up.
Kris Rachford
69 Cobra 428CJ 4 Speed
C/S 3032
Old 02-01-2013, 05:35 AM   #2
bad440
bad440's Avatar
what happened bill?did it pop a gasket already?
bad440 is offline   Reply With Quote
Old 02-01-2013, 09:14 AM   #3
Dwight Southerland
Dwight Southerland's Avatar
Liked 783 Times in 195 Posts
Bill -
Call Johnny Case at Case Machine and ask him. He knows lots of machine shop people around the state. Also, somebody in LR has an Isky tool because the drag boat people used to do that a lot on aluminum head BBCs. Call Leonard at Auto Sports Center 501-375-7223.
Old 02-01-2013, 12:37 PM   #4
Run to Rund
Liked 54 Times in 27 Posts
It seems the biggest problem comes when a machine shop isn't careful enough to keep the groove depth uniform.
Old 02-02-2013, 09:04 AM   #5
bill dedman
Liked 6 Times in 4 Posts
Jeff, the block is already installed in the car. I just want to do rthe head.
Bill
bill dedman is offline   Reply With Quote
Old 02-02-2013, 09:29 AM   #6
bill dedman
I'll keep that in mind; thanks for the tip!!!
Bill
Old 02-02-2013, 09:45 AM   #7
gonzo1066
You should be able to put a grooves in the block with the Isky GrooveOmatic while the engine is in the car. Vary small radius required and simple to use.
gonzo1066 is offline   Reply With Quote
Old 02-02-2013, 05:11 PM   #8
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Cutting the head is different from the block,the Isky tool everyone is talking about is for the block ONLY not the head. BHJ makes tool for heads has plate similar to torque plate that bolts to head to locate cutter assm.
You can cut head on boring bar or mill but you have to have a way to center it or locate so you can cut the grooves in the correct place,when you do the block you locate off cylinder bores like you do when you bore cylinders,the head does'nt have a way to locate where to cut.
Someone that is real good on bridgeport w/ dro could map the bore centers w/dowels as reference point then transfer that to head and locate bore centers and cut the grooves,but it would be big job to do that way.
I don't know what kind six you are workin on But if it has same bore centerline as a V-8 someone has plate for to cut receiver grooves then could possibly adapt to use on 6 cyl.
Mike Taylor 3601
Old 02-02-2013, 09:24 AM   #9
bill dedman
Nope; just looking down the road at the time when I have 25+-pounds of boost and that is a real possibility.
I should have thought about that before the block went into the engine bay...
20/20 hindsight...
Bill
Old 02-02-2013, 09:19 AM   #10
bill dedman
Thanks, Cobra; I need to talk to him, anyway...
Bill
