Old 01-24-2013, 09:51 AM   #51
Mike Taylor 3601
Mike Taylor 3601's Avatar
Liked 308 Times in 103 Posts
Default Re: Under the index for under a grand!
I use to have a set of buckets in my V/S malibu that same material. I don't think that they were that ugly in the late 80's
Mike Taylor 3601
Old 01-24-2013, 02:06 PM   #52
Cheapo tips 1
I'm sure Billy knows this one, but on those old trailing arm cars, the rubber bushings get very gushy and weak after a while... Rather than making or buying something, just take a batch of 1" drywall screws and your battery drill, and run them into the rubber , 6-8 in each bushing, both sides ..Instant firmness!
2, Those A, later G bodies had a factory anti roll , or sway bar on the Monte's ,GN 's and even Malibu police cars. When you install the proper sleeves, bolts and bar, you stiffen up the lower trailing arm in the process. The holes are already there.
Old 01-24-2013, 06:10 PM   #53
nickh
nickh's Avatar
Liked 657 Times in 197 Posts
Great fun following this thread. Billy I will donate a brand new UNI Filter 14" diameter (have them in 3, 4 & 5") let me know it comes already pre-oiled from factory the car may pickup .003 with it...LOL
I bought my first new car 1981 Monte Carlo Sports Coupe, had the 267 V8 the car could be outrun by the local ice cream truck. it had the charcol prefilter element inside the housing, called chevy and they said that it would void the warranty if I took it out, when I got home I sawed it off, then I put a test tube from western auto in place of the catalytic converter. The best I ever got out of the car at the track was a 19.51 @ 69 mph...LOL
nickh is online now   Reply With Quote
Old 01-25-2013, 04:35 PM   #54
pontiacchuck
i'm interested in the manual brake stuff if you wanted to make a set for me I ASLO HAVE AL. BUMPER BACKING FOR FRONT gm had al hoods to hard to find i have one but it has hood scoop on it so i do not think you can use it may have rear bumper al backing i run 80 gp et bracket i boxs in all rear arms and it helps alot stock coils and car lifts front and goes st upper ones are abount 3 in higher to change angle i use 9 in ford from a ford truck 70
pontiacchuck is offline   Reply With Quote
Old 01-31-2013, 12:50 PM   #55
Billy Nees
Liked 7,789 Times in 1,744 Posts
Well I managed to get the fuel system and electrical stuff pretty much done yesterday. This morning I started installing the tach and some cheapie gauges.
Dime Rocket tip of the week!
I must have about a half a dozen "non-functioning" Autometer tachs in my shop as I'm sure some of you do too. I picked out a model #6809 that decided it didn't want to work over 5k RPM and contacted Autometer. They told me where to send it and if they couldn't fix it there would be no charge. Well I boxed it up, sent it out and got back a VERY nicely redone tach. Price? $25. Nice to deal with and done promptly, thank you Autometer!
$250 tach for $25!
Billy Nees 1188 STK, SS
Old 01-31-2013, 02:52 PM   #56
HR9121
HR9121's Avatar
$250 tach for $25!
Thanks for spoiling my lunch Mr Billy, I just chunked one about 2 weeks ago. Good luck in your project, I've enjoyed reading it.
James Williamson
W200 J/SA. SS/JA
Old 01-31-2013, 02:55 PM   #57
Michael Beard
Michael Beard's Avatar
Liked 13 Times in 9 Posts
$250 tach for $25!
Where's the "like" button? That's awesome! Kudos to Auto Meter!
Old 01-31-2013, 05:38 PM   #58
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
Fuel system is done except for mounting regulator and making line to carb.
$10 used cooling fan and a piece of scrap aluminium fixed my broken shroud and will work well.
"Dime Rocket" tip of the week! 80s GM cars have Bosch Relays and neat mounting brackets that can go anywhere and they're all over junkyards.
First pics of my NHRA approved racing seats! Ya know, I always liked that throw pillow motif! I wonder if it would be legal to mount a discoball in the back!
I need you to make me a shroud for the big girl.
Bob Bender 144 O/SA
Old 02-01-2013, 05:57 AM   #59
Tom keedle
Tom keedle's Avatar
Liked 8 Times in 7 Posts
$250 tach for $25!
don't suppose you'd share that address (or do i/we need to go thru autometer for that?)
Old 02-03-2013, 10:44 AM   #60
jcw31
Liked 6 Times in 6 Posts
Billy, have you made any progress/decisions with the engine,trans,
suspension combos yet?
Joe
jcw31 is offline   Reply With Quote
