Old 01-22-2013, 05:05 PM   #1
Bob Pagano
Bob Pagano's Avatar
Liked 16 Times in 11 Posts
Default Re: BB Mopar Oil Drainback Modifications???
Sounds like to much oil pressure, put in a softer spring in the pump.
Bob Pagano A/SA
Old 01-23-2013, 02:09 AM   #2
GTX JOHN
I have run the Indy heads on 1/2 Stroker 440 with just a Milodon pan and pump
with only eight quarts. I run Mobil on 10-30 synthetic with Zero problems.
I had issues with Oil foaming and nearly emptying the pan only when I ran a 15 - 50 Conventional Non syn. oil early on with the engine. I do not know if it was
the higher oil pressure or the foaming slowing the return or possibly
both working together that was the problem.
I since have broken the engine in and change oils before making a hard pass
on the bracket cars.
Hope this Helps!
GTX JOHN is online now   Reply With Quote
Old 01-23-2013, 10:53 AM   #3
acme383
I started to think about when did i start having this problem. I think it is from the Main stud girdle that i put on it. not enough room for the oil to drain back at a fast enough rate. it was probably acting like a second windage tray. now i purchased an aftermarket mega block. so bye, bye stud girdle. What oil pressure would you recommend? i have an adjustable milidon spring set up in the pump. i usually try to limit to 80psi going down the track.
acme383 is offline   Reply With Quote
Old 01-23-2013, 12:34 PM   #4
Bob Pagano
Bob Pagano's Avatar
Milodon system run on Steins cars back in the day, never went over 60 # or it would empty the pan.
Bob Pagano A/SA
