Old 01-14-2013, 01:37 PM   #1
Jeremy
Default Stock class racing seats
I was just wondering if anyone has any thoughts on the Jaz Polyethylene racing seats? Also do you think are the Summit/Jegs brand the same as the Jaz brand?
Thanks Jerry
Jeremy is offline   Reply With Quote
Old 01-14-2013, 03:26 PM   #2
Jim Kaekel
Liked 535 Times in 110 Posts
Default Re: Stock class racing seats
You would be better off in the long run with an aluminum seat. The plastic seats have molded-in threads that can pull-out over time. A friend has one of those in a bracket car and after two years, the threads are already starting to pull-out of the seat, and he's not a real heavy fellow either. My .02.
Jim Kaekel 3836 STK
Old 01-14-2013, 09:58 PM   #3
Mark Markow
Mark Markow's Avatar
Liked 9 Times in 3 Posts
x-s2 on the aluminum seats. leave the poly seats to the grade school cafeteria's
Mark Markow
171 ss/tb
Mark Markow is offline   Reply With Quote
Old 01-15-2013, 02:13 AM   #4
Phillip marvetz
Phillip marvetz's Avatar
Talking Re: Stock class racing seats
Chad should be here any second to scold you.
2009 V/SA Record Holder
Old 01-18-2013, 09:40 AM   #5
Chad Rhodes
poly seats belong in dune buggies ( or Phillip's car). As much as I disliked being required to run seats that in some cases are over 50 years old, installing a plastic one with molded in "inserts" seems even worse. There Phillip, are you happy now. Wasn't even going to reply till i read your reply.
Chad Rhodes 2113 I/SA
Old 01-18-2013, 11:42 AM   #6
Bob Bender
Bob Bender's Avatar
Liked 460 Times in 91 Posts
I will keep my bench.....
Bob Bender 144 O/SA
Old 01-18-2013, 12:38 PM   #7
You daredevil, you
Old 01-18-2013, 12:48 PM   #8
Ed Wright
Ed Wright's Avatar
Mine have through bolts. I can't imagine anybody trusting threaded bolt holes I. Their seats, no matter what they are made of.
Ed Wright 4156 SS/JA
Old 01-18-2013, 01:53 PM   #9
Mike Pearson
Mike Pearson's Avatar
Liked 1,943 Times in 584 Posts
Thanks Jerry
I think I have the summit seats. I have the driver side thru bolted to the floor and cage. Nice comfortable seat. Light weight too.
Mike Pearson 2485 SS
Mike Pearson is online now   Reply With Quote
Old 01-18-2013, 07:40 PM   #10
SuperStockDodge
SuperStockDodge's Avatar
Thumbs up Bob!!!
Sean Fischer 5864 SS/E
SuperStockDodge is offline   Reply With Quote
